  Soarer Central * Suspension * Light weight Jap Rims Previous Previous    Next Next
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 02:01 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Right so, the quote i requested for a full set of Garsons came through and it's a good price. I just have to first sell my Soarer so i can raise the funds to buy those rims for my Soarer...wait what? For those interested, $4750 landed in Perth hahahaha.
And just coming back from the track day, getting some light weight rims doesn't seem like a bad idea. So the question i have is, anyone know of some of the lighter rims available on the market today? I put jap cause i assume only jap rims come in lightweight lol.
Ali Saeed
Tuesday, July 26, 2011 - 05:24 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
um you can some Works and Enkei, both pretty lightweight and good quality for around $2k for 18s
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Tuesday, July 26, 2011 - 06:04 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yang, many Work, Volk and BBS wheels come in a light weight model, others are semi-cast or have a forged barrel, SSR SP1s for instance are 100% cast, where as the competitor Work Meister S1s are forged.
Look for the 2-3 piece forged wheels as these are stronger, lighter and pieces can be replaced, rather than the whole rim if damage occurs!
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 06:26 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cheers for the input guys,
Yeah been looking at the Work Meister S1Rs and the Gram Light 57s PRO. Thinking 18 x 8.5/9.5 with +48/+45 (Front / Rear). Thinking of the sorta flush but nothing crazy look hahaha
Ali Saeed
Tuesday, July 26, 2011 - 06:28 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
+48/45 wont be flush.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 06:41 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
+50 is flush isn't it, so 48/45 will stick out a tiny bit? Or have i got this whole offset thing waaay off
Ali Saeed
Tuesday, July 26, 2011 - 06:51 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
+50 is stock offset, which is quite tucked in. the lower the offset the more the wheels will stick out. mine are 18x8 +35 and they are about an inch from being flush.
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Tuesday, July 26, 2011 - 06:57 pm, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OH are you serious...god damn i was under the assumption that +50 was flush..Thanks for the heads up hey...i just assumed stock offset = flush..
HMM will have to reevaluate, might take my current wheels off this sunday and measure them.
Ali Saeed
Tuesday, July 26, 2011 - 07:08 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"you can go as low as +38 on a 10” wide wheel in the rear without any fender modifications and as low as +22 on a 10” wide wheel with your fenders rolled. your tire size plays a big role here."
http://www.clublexus.com/forums/sc-400-300/290699-official-wheel-and-tire-fitment-guide-for-sc300-sc 400.html
Aaron Casey
Tuesday, July 26, 2011 - 08:35 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
18x10 +18 with 235's rolled guards
Victoria (The Nazi State)
Pretty Red Thing and The Black Beast
Tuesday, July 26, 2011 - 10:10 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm running 18x10 +45, 275's and they just rub a tiny bit on unrolled stock rear guards.
Gary Poloskei
A.C.T
Soarer JZZ30
Reg: 01-2008
Friday, July 29, 2011 - 02:37 pm, by:  Gary Poloskei (Mikrucio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Lightweight and japanese?
The STOCKIES. you cant really beat the 16's
JZZ30/UZZ31/JZS160
Friday, July 29, 2011 - 11:38 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry but Garsons? Light??? Highly doubtful if they are the ones I'm thinking of.
Look into Work Emotions or the like.
Matt Sartori
Rx7
Reg: 08-2008
Saturday, July 30, 2011 - 01:20 am, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Desmond Regamasters.
hard to get in decent sizes in 17"
Rare to get in decent sizes in 18"
But they're a strong lightweight 1 piece forged wheel from russia(?) i believe...they weigh 5kg each
They're a simple 5-spoke design with stepped dish, they're my all time favourite rim, lots and lots of track cars use them and they're really sought after, Gives it a serious track-car look in my opinion.
http://ispycleanimports.tumblr.com/photo/1280/5597081093/1/tumblr_lldg0nnr7z1qeq86w
http://philscarblog.files.wordpress.com/2009/11/fcevo.jpg
http://yogihugo.files.wordpress.com/2010/09/fc3s-desmond-regamaster-evo.jpg
Yang Gao
Soarer UZZ31 V8
Reg: 05-2011
Saturday, July 30, 2011 - 10:54 am, by:  Yang Gao (Ryugen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@Jose I was thinking Garsons before the track day..now that i've felt the amount of weight my mind has changed.
@Matt WOW imma liking those rims...cheers for that
Ben Lipman
Saturday, July 30, 2011 - 07:18 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matt- They don't look like they would clear a decent set of brakes though?
Matt Sartori
Rx7
Reg: 08-2008
Saturday, July 30, 2011 - 08:29 pm, by:  Matt Sartori (Klutch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i've seen them run on STI's and Evo's with brembos..and remember seeing an R32 GT-R with them.
I dont think big brakes is an issue..but i could be completely wrong, you could always run a bolt on spacer to clear it i guess?
Jay Asghari
'94 UZZ31 GTL, '94 TT, '96 UZZ32
Reg: 01-2010
Friday, March 02, 2012 - 01:31 pm, by:  Jay Asghari (8pack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jose, how much do the stockies weigh?
Aaron Casey
Friday, March 02, 2012 - 06:29 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Them wheels are definitely desmond regamasters. Great wheel and pretty light. They can accommodate larger brakes on nissans due to the hub/rotor design you would have to get very large offset for big brakes on soarer/supra. Would fit tt brakes fine though. Unless running spacers but i dont recommend spacers though if possible
Robert Hubeek
JZX81
Reg: 05-2011
Saturday, March 03, 2012 - 01:28 pm, by:  Robert Hubeek (Hizoku) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got a pair of the Desmond Regamasters. in 17 x 9 +18 on my JZX81 and they clear R32 GTR calipers. (conversion i have done) Cost $1000 the pair but yes they are SUPER LIGHT
Also know of a pair of close to same offset but in 10s for sale
JZZ30/UZZ31/JZS160
Saturday, March 10, 2012 - 07:35 am, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jay Asghari wrote on Friday, March 02, 2012 - 01:31 pm:
I wouldn't know, I've never had a set of stock Soarer wheels on any of my Soarers lol. My genuine 17" GS300 wheels seem to be pretty light for what they are though.
Mmmmmm Regamaters are super nice but very hard to find now.
Aaron Casey
Saturday, March 10, 2012 - 12:03 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Technically regamasters are russian lol
