  Soarer Central * Suspension * What is the diff ratio on 3 ltr soarer auto Previous Previous    Next Next
John Stafford
Qld.
Soarer UZZ31 GT-L V8 and a UZZ32 # 514
Reg: 02-2010
Saturday, December 10, 2011 - 12:51 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am looking at a diff on Ebay that is out of a 3 ltr soarer auto and want to know the ratio and if I would be ok for my 32? Cheers John
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Saturday, December 10, 2011 - 08:10 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It'll be 4.1 same as a TT, but most likely an open diff, not LSD.
It's slightly shorted than the stock V8 diff, so you will get slightly better accelleration, but a couple of hundred revs higher cruising down the freeway.
John Stafford
Qld.
Reg: 02-2010
Saturday, December 10, 2011 - 11:14 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
found another one: a Mk3 supra torsen LSD and the guy said it would go on my V8. Is this correct? It only has 105,000 klm. Thanks again for the help Cheers John
Blake Gloyn
manawatu
soarer JZZ30 TT
Sunday, December 11, 2011 - 06:19 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no the mark 3 supra ones are not a straight fit into the z30 series soarers or jza80 supra or aristos.
John Stafford
Qld.
Reg: 02-2010
Sunday, December 11, 2011 - 09:05 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Blake, and thanks Dan for your regular input. It looks like the shaft bolts on a mark 3 would be different at least. I also looked at a non torsen set up with subframe, shafts, brakes, but not sure if the 32 with its rear wheel steer would take a normal subframe? This is all fun not having even looked at the 32 yet as I am must preparing for when I come home to get it all up and running as soon as possible. Cheers John
Sunday, December 11, 2011 - 01:07 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mk3 Supra is a totally different diff.
Any diff from a 30 series soarer or 80 series supra will fit. It's the the ratios that are different. (except TT supra)
If you get the subframe setup then just remove the diff from the subframe and fit the diff to your car.
John Stafford
Qld.
Reg: 02-2010
Sunday, December 11, 2011 - 01:30 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Dan, I got an open V8 diff at a good price to get things running and am looking at a torsen, just confirming that it is either an A01B or a A02B before buying. I found a table on soarer world that helped me figure things out along with some info on a previous post by someone SC that told me how to read the transaxle code. Cheers John
