  Soarer Central * Suspension * Prothane bushes Previous Previous    Next Next
Stephen Shackleton
UZZ32
Reg: 01-2008
Tuesday, March 27, 2012 - 11:07 am, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anybody had any experience with Prothane? The link below is for a complete front control arm set. $103.00 delivered
http://www.ebay.com/itm/140661703307?item=140661703307&viewitem=&sspagename=ADME:X:eRTM:MOTORS:1123& vxp=mtr
David Watt
Tuesday, March 27, 2012 - 02:00 pm, by:  David Watt (David_w) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I haven't, but thats half what it would cost for Whiteline
Allan Langford
Reg: 05-2010
Tuesday, March 27, 2012 - 02:14 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doesn't the UZZ32 use different bushes???
also the bal joint was on the way out not long after doing bushes in mine, ended up getting new JZA80 arms that come fitted with solid rubber bushes
Stephen Shackleton
UZZ32
Reg: 01-2008
Tuesday, March 27, 2012 - 02:18 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This link is cheaper $89.00 for the 8 bushes, Rubber bushes would cost nearly $500.00
http://www.ebay.com/itm/18-207-SC300-SC400-92-96-Front-Control-Arm-Bushing-Kit-/180736600836?pt=Moto rs_Car_Truck_Parts_Accessories&fits=Model%3ASC400&vxp=mtr&hash=item2a14bdab04#shId
Stephen Shackleton
UZZ32
Reg: 01-2008
Tuesday, March 27, 2012 - 02:25 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think the bushes are the same, different lower control arms though, not sure about the ball joints maybe a 32 owner has some info?
Jamie Richards
St.john's
v8
Reg: 06-2009
Wednesday, March 28, 2012 - 01:57 am, by:  Jamie Richards (Nwb40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there ok had a set installed in my car about 2 years ago still going strong
Stephen Shackleton
UZZ32
Reg: 01-2008
Sunday, April 08, 2012 - 12:57 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
3 hours and the 4 control arms are off the car. A rattle gun and the Pitman arm puller makes it easy.
Anyone purchased the rubber boots for the struts lately? or an equivalent that will fit? I will try Toyota on Tuesday the rotors still measure 31.5 mm so should be machineable, just need to find some pads at a reasonable price.
Allan Langford
Reg: 05-2010
Monday, April 09, 2012 - 08:53 am, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
looks like that lower arm already has poly bushes in one joint!
Stephen Shackleton
UZZ32
Reg: 01-2008
Monday, April 09, 2012 - 01:24 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not original maybe, anyone seen this type of bush before?
Tom Richards
Monday, April 09, 2012 - 01:56 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i purchased replacement boots for the LCA ball joint from bursons last yr. From memory about $17ea
Eugene Smith
Reg: 02-2012
Monday, April 09, 2012 - 03:47 pm, by:  Eugene Smith (Eugene) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I need to replace all my bushes as well all wheels are stuffed. Can you let me know how many of what to order so I can replace mine too? My car is garaged now and can not be driven. Too unstable. Please p email me on what exactly to buy. Thanks guys you are a inspiration for me.
Stephen Shackleton
UZZ32 #166
Reg: 01-2008
Monday, April 09, 2012 - 05:07 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depends on your budget Polyurethane is cheaper but may not give as good a ride as rubber. The link for rears in Polyurethane :-) Fronts bushes in good rubber are about $500, rears would be dearer because their are 14 bushes
http://www.ebay.com/itm/18-304-SC300-SC400-Rear-Control-Arm-Bushing-Kit-92-96-/170685669124?pt=Motor s_Car_Truck_Parts_Accessories&vxp=mtr&hash=item27bda89f04#ht_500wt_1183
Victoria (The Nazi State)
Pretty Red Thing and The Black Rattler
Monday, April 09, 2012 - 06:20 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
www.soarerparts.com.au for rubber bushes. Ebay or superpro for poly bushes.
Allan Langford
Reg: 05-2010
Monday, April 09, 2012 - 09:20 pm, by:  Allan Langford (Allan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
interesting someone has just bushed one arm... might of had one arm replaced at some stage due to damage or a worn ball jont... would of made handling "interesting" to say the least!
Steven Soknacki
Ontario
'92 SC400 and '94 GT-T Limited
Reg: 07-2006
Tuesday, April 10, 2012 - 04:36 am, by:  Steven Soknacki (Sc_coupe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anyone had experience with the Prothane Swaybar bushes?
I attempted the install this weekend and found the fronts to be straightforward and a proper fit (30mm). However, the rears seemed to big (24mm) compared to the stock rubber ones so I stayed with those out back.
Has anyone had the same issue? From further research, I am thinking the correct rear sway bar size is 22mm, which explains the discrepancy, yet the kit is for SC300/400. Are our rear sway bars 2mm thinner than SC's, or has Prothane made a mistake?
Stephen Shackleton
UZZ32 #166
Reg: 01-2008
Wednesday, April 11, 2012 - 04:53 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anybody have any front Active strut rubber boots for sale? Toyota tell me they are ex Japan at least 4 weeks away.
Stephen Shackleton
UZZ32 #166
Reg: 01-2008
Wednesday, April 18, 2012 - 11:07 am, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I took the LCA's to a suspension shop where I will have the wheel alignment done and they reckon none of the bushes need replacing, just re-grease the urethane bush and reassemble, strange that some look like original and it has 220K's on the odo.
I have a set of Prothane front bushes for sale if anyone is interested.
$90.00 plus postage
Lloyd Roberts
Reg: 03-2011
Wednesday, April 18, 2012 - 09:55 pm, by:  Lloyd Roberts (Lloydulation) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm of the opinion that even though they don't need changing it will still improve the ride significantly by changing to brand new ones :-)
Since you're going to all the effort to remove the arms i'd change them anyway.
David Watt
Wednesday, April 18, 2012 - 10:16 pm, by:  David Watt (David_w) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So... someone spell it out for me
LCA bushes + steering rack bushes?
Or something else too?
Stephen Shackleton
UZZ32 #166
Reg: 01-2008
Wednesday, April 18, 2012 - 10:32 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Old rubber, not worn out will be better than hard urethane bushes, my problem was steering rack bushes which I have replaced with urethane as oil will not cause a problem as there are some leaks.
Lloyd Roberts
Reg: 03-2011
Thursday, April 19, 2012 - 09:46 am, by:  Lloyd Roberts (Lloydulation) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh ok. I bought a set of genuine LCA bushes from that cheap toyota parts uk place. I don't think you can get replacement bushes for your bush for the hydraulic strut though. I don't have anything that fancy on my normal soarer LCA.
Stephen Shackleton
UZZ32 #166
Reg: 01-2008
Thursday, April 19, 2012 - 01:20 pm, by:  Stephen Shackleton (Shack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nothing wrong with normal soarers, 32's are just different and probably worth less if something goes wrong its more expensive to fix.There's a 92, UZZ32 on Ebay went for $910.00 but did not reach the reserve, relisted for $3000.00 hope it finds a good home :-)
Lloyd Roberts
Reg: 03-2011
Thursday, April 19, 2012 - 01:33 pm, by:  Lloyd Roberts (Lloydulation) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there's definitely something special about the UZZ32. Conventionally suspended soarers are already beautiful to drive - the active sus and 4ws must add another dimension. If anybody has an active in Syd i'd love to go for a drive someday!
