  Soarer Central * Suspension * V8 diff In to twin turbo Previous Previous    Next Next
Jeremy Fissioli
West australia
Soarer twin turbo
Reg: 06-2011
Friday, June 22, 2012 - 09:45 am, by:  Jeremy Fissioli (Jezza91) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys
Sorry if this has been asked before I'm in desperate need of a diff and I can only find the v8 one has anyone ever used the v8 diff on the 1jz??
What was needed to be done
Thanks
Ali Saeed
RSP GT-T
Friday, June 22, 2012 - 09:50 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
nothing needs to be done, it will bolt up fine, but the diff ratio is different. TT diff ratio is 4.08 and V8 ratio is 3.9. Just means you will have more top end but slower acceleration
