Wednesday, August 15, 2012 - 07:29 pm, by: Lance Mcdonald(50ror)
my uzz31 is broken down with the air bag suspension right down, is there any way to get the suspension back up so i can get it on a tow truck and get it home
Wednesday, August 15, 2012 - 08:04 pm, by: Scott Vim(1uz1jz)
How far are you from home. Same thing happened to mine. I just went very slowly since I was only a few kms away. Tyre would only rub over bumps in the road.
Wednesday, August 15, 2012 - 09:34 pm, by: Lance Mcdonald(50ror)
the car want start it keeps blowing the inj fuse and its about 10mm off the ground at the lowest point so it cant go on a trailer or tow truck, i would like to at least be able to get the suspension up so i can get it home as its not really at a safe place to leave a car
Thursday, August 16, 2012 - 10:24 am, by: Paul Drane(Paulwd)
Lance do you drive around with your car as low as you have it in profile pic, if so you have probably worn through the wiring loom on the drivers side and is causing your starting problems. Some of the tow truck companies have special flat tops that are able to tow your car, but it will cost you extra for them.
Thursday, August 16, 2012 - 11:02 am, by: Lance Mcdonald(50ror)
nah i dont drive it around like that, but that is where it was shorting out, i found it this morning and fixed it up and the car is home safe, thanks for the help anyway
