  Soarer Central * Suspension * CV Shafts leaking near bolts?? Previous Previous    Next Next
Gary Poloskei
A.C.T
Soarer JZZ30
Reg: 01-2008
Sunday, December 02, 2012 - 07:08 am, by:  Gary Poloskei (Mikrucio) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello Guys and gals
My rear end is in bits at the moment, just changed out my subframe bushes. however before I put it all back together again i think I have another problem
When I pulled the drive shafts from the diff, there was ALOT
of green ooze from behind the bolts. At the top of the shaft
there is a dome like piece that fits snuggley into the diff to centre it
could this be leaking out grease? my diffs not leaking at least
I think its not, coz my diff oil is brown and this stuff is dark green.
The boots on the shafts are clean and not leaking, I wonder if there is a seal at the top that may have let go. both sides are leaking, but one side is worse that the other.
What do you all think?
Daniel Marshall
V8 UZZ31 X2
Reg: 07-2011
Sunday, December 02, 2012 - 08:46 am, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought it was greased from factory to prevent heat transfer and bonding?
The green ooze is probly 20year old grease.
I may be wrong. But both soarers I've pulled shafts off had this.
Costa Tsimiklis
386.2 rwkw the old T51S setup - New Setup HKS T51R SPL -Going for 450rwkw on Pump Gas!
Reg: 07-2008
Sunday, December 02, 2012 - 04:36 pm, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CV Joint grease coming from the backing plate / bolt holes.
If you're concerned that there's too much grease, I would get your CV joints re-packed as that's where it's come from.
