  Soarer Central * Suspension * Help please! DEFECTED! Previous Previous    Next Next
Hexxle Henderson
Supra; Soarer soon.
Reg: 08-2011
Monday, December 03, 2012 - 10:30 am, by:  Hexxle Henderson (Hexxle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi fellas,
I made the mistake of driving through the city on a Friday night, lo and behold I was defected for being too low. My question is if I can borrow anyones stock JZZ30 front struts for a few days while I take it to the inspection station, and you can have them back after that - in the Sydney area obviously.
There's a case of your choosing in it for anyone who can help.
Cheers,
Alex.
Ryan McDonough
Monday, December 03, 2012 - 02:05 pm, by:  Ryan McDonough (Ryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What suspension do you currently have in your car?
David Henderson
Nsw
Reg: 08-2007
Tuesday, December 04, 2012 - 09:07 am, by:  David Henderson (Hendo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a set of old bilsteins, no springs or top hats though
Hexxle Henderson
Supra; Soarer soon.
Reg: 08-2011
Tuesday, December 04, 2012 - 09:09 am, by:  Hexxle Henderson (Hexxle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have Powered by Max coilovers; specifically designed for the stance oriented. No one has stock struts?
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Tuesday, December 04, 2012 - 09:30 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They can't be adjusted? How low is it. Tyres are in the guards?
Ryan McDonough
Tuesday, December 04, 2012 - 01:51 pm, by:  Ryan McDonough (Ryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If they are coil overs you should be able to adjust the height. It would be alot less work, and effort to do that, than to change the units over.
Hexxle Henderson
Supra; Soarer soon.
Reg: 08-2011
Tuesday, December 04, 2012 - 02:22 pm, by:  Hexxle Henderson (Hexxle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks David, but that isn't really a help. I have the stock struts, I just don't have any springs to go with them.
Hexxle Henderson
Supra; Soarer soon.
Reg: 08-2011
Tuesday, December 04, 2012 - 02:23 pm, by:  Hexxle Henderson (Hexxle) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well I'll give it a try, but the highest ride height isn't exactly really high. I guess I'll have to call up the inspection station and see what the deal is.
Tuesday, December 04, 2012 - 03:33 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Minimum 100mm ground clearance for any part of vehicle ( they use a little trundle wheel thing to check ) , and I think there is a minimum height from centre of wheel to guard lip clearance ?
Ryan McDonough
Tuesday, December 04, 2012 - 06:52 pm, by:  Ryan McDonough (Ryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have never seen a set of coilovers that wouldnt lift the bottom of the stock car above 100mm.
Aaron Casey
'94 2jz JZZ30 gttl, '93 UZZ31 track, VT, 2x Leyland Mini's
Tuesday, December 04, 2012 - 11:46 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ryan mine dont.. They are supra coilovers from jic. At highest settings i get about 105mm front and 87mm rear..
Will totally depend on what the defect is for. Is it a ride height defect specific or is it stipulating part of the defect is aftermarket suspension? If its just height and only partial inspection (pink) can just raise it.. If its full inspection (blue) then will have to swap struts.
Ryan McDonough
Wednesday, December 05, 2012 - 03:33 pm, by:  Ryan McDonough (Ryan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL I knew if it was going to be anyone who had a set that didnt it would be you!
Thursday, December 06, 2012 - 12:05 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.facebook.com/pages/Anti-Stance/422706411108821?fref=ts
