  Soarer Central * Suspension * Any other places to get crown and pinion Previous Previous    Next Next
Nik Peacock
Tasmania
V8 6 Speed Manual
Reg: 05-2006
Tuesday, May 21, 2013 - 01:01 pm, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does any one have any other options to source a new crown and pinion 3.9 ratio, other than Castle hill or Amayaya, reason being I had a trd 2 way installed by a so called expert and it now has a whine on neutral throttle, it did have 1 trip to the drags in the 1st month after install but I would have expected it to be able to take some spirited driving. Not interested in 2nd hand
Evan Kaio
Quiwiland NZ
'91 UZZ31. 92 TT
Reg: 01-2007
Wednesday, May 22, 2013 - 05:59 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You could try Rutherford and Bond here in Wellington NZ.
