  Soarer Central * Suspension * Air bag suspension diagram Previous Previous    Next Next
Peter Arnull
SC400 (V8)
Reg: 02-2013
Tuesday, January 28, 2014 - 10:28 am, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have recently replaced the front units and now the car seems to sit quite low. I have no errors up. I also realise that my cd does not any information (circuits or otherwise) on air suspension. I have managed to find where the fuse is and I plan to check it tonight. I have done a reset. Can anyone tell me where I can get information and possibly circuit diagram on the air suspension system.
Tom Richards
Tuesday, January 28, 2014 - 01:57 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does the pump come on? switch from normal to high and check.
Peter Arnull
SC400 (V8)
Reg: 02-2013
Wednesday, January 29, 2014 - 07:23 am, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The pump is not running. I tried to find the fuse however the cover of the inside fuse panel showed a row of seven fuses and there were only six on the actual fuse panel. There were two fuses floating near the fuse panel which were both OK. I imagine there is a relay somewhere so that I can check if the controller is calling for the compressor. I was thinking of checking the compressor. However I have to sych myself up to pull the inner guard off etc. I have tried switching from normal to high and turning the isolation switch in the boot on and off.
Tom Richards
Wednesday, January 29, 2014 - 12:00 pm, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
any help?
http://soarercentral.com/sc-forum/messages/30604/355075.html
Peter Arnull
SC400 (V8)
Reg: 02-2013
Wednesday, January 29, 2014 - 12:38 pm, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Tom, I managed to get hold of a circuit diagram and there appears to be a fuse in a location called FL Cassette block. This fuse supplies a + to the compressor. I may be able to get a air suspension ECU to try. The other option is to prove the compressor by disconnecting the plug to the controller and applying DC to the motor. I will keep you posted.
Peter Arnull
SC400 (V8)
Reg: 02-2013
Thursday, January 30, 2014 - 07:25 am, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The compressor is dead. I have sourced another locally and just hope that is all that is wrong.
Peter Arnull
SC400 (V8)
Reg: 02-2013
Monday, February 03, 2014 - 07:45 am, by:  Peter Arnull (Boyscout0_2) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Repaired and replaced the compressor and all is working. The weather sealing on the top end of the compressor seems to be a bit ordinary. With mine the brushes in the motor were sticking due to corrosion
