  Soarer Central * Suspension * Diff ratio Previous Previous    Next Next
Noel Howlett
soarer v8 base model
Reg: 04-2013
Saturday, March 01, 2014 - 10:46 pm, by:  Noel Howlett (Growl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all,
I have asked this question before.
Will a hilux crown wheel and pinion fit into a ssoarer pumpkin.
Only asking again as I just saw a torsen centre on ebay and he claims it will fit a hilux with using a three mm spacer.
So the crown wheel must be the same bolt pattern.Both 8 inch Toyota diffs.
der.just remembered I have a hilux and a soarer.
Best I stick my head under tomorrow and do some eyeball measurements.
Would be great to hear if any one has put the parts side by side.
Maybe on inspection it will be an obvious no.
I am chasing a diff ratio of maybe 4.3 to 1
All thoughts welcome.
Blake Gloyn
manawatu
soarer JZZ30 TT
Sunday, March 02, 2014 - 02:54 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i think it is the jza70 torsen that fits a hilux case, (with the use of a spacer). I've never seen anything on the net where the hilux bits have been fitted to a jzz30 or jza80 pumpkin.
there was a 4.3 sold on this forum about a year ago. From memory, the v8 owner had imported a crown wheel and pinion from USA, as one of the non turbo supras and the lexus SC400s run a 4.3 diff.
Ali Saeed
RSP JZZ30
Sunday, March 02, 2014 - 11:33 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok so the 4.27 (4.3) ratio was used in the following applications:
1993-1996 USDM Toyota Supra NA (2JZGE) 4AT and 5MT
1991-1993 USDM Lexus SC300 (2JZGE) 4AT
1995-1997 USDM Lexus GS300 (2JZGE) 4AT
The part number for the ring and pinion is 41201‑80028.
Noel Howlett
Reg: 04-2013
Monday, March 03, 2014 - 11:30 pm, by:  Noel Howlett (Growl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks this is the quality imformation I was hoping for.
Liviu Velisarie
Romania
JZZ30 GT-TL
Reg: 05-2012
Monday, March 03, 2014 - 11:35 pm, by:  Liviu Velisarie (Greenroadster) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
@ALi Saed - So, if a Lexus SC300 has a diff with 4:27 ratio, a Soarer JZZ31 would have what ratio? The same I supposed.
Also, I see you are quite familiar with part numbers...Can you help me find the part numbers for all Soarer bushes? Upper-lower, front-back, sway, steering and diff?
Blake Gloyn
manawatu
soarer JZZ30 TT
Tuesday, March 04, 2014 - 07:35 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no, the soarer never had the 4.27 ratio. No model, ever.
Nik Peacock
Tasmania
Blown V8 6 Speed Manual
Reg: 05-2006
Tuesday, March 04, 2014 - 08:43 am, by:  Nik Peacock (Niko) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I bought the 4.27 from Lynden Phillips to put behind a t56 as the rpm was just a bit too low with the 3.9 v8 ratio it's now perfect, Lynden may be able to help you with where he got it from
Noel Howlett
Reg: 04-2013
Monday, June 16, 2014 - 08:18 pm, by:  Noel Howlett (Growl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry meant say thanks Niko a while back I checked out your car. very nice
