Tuesday, September 05, 2017 - 06:27 am, by: John Stafford(Johng12)
I am doing up a 31 with air suspension, I haven't worked on air suspension before, my own car has coil-overs. This car has the left hand side of the suspension down so that the guards are 2 fingers above the tires, both front and back, while the right hand side is 4 fingers above the tires, both front and back. It doesn't go any lower than that, so I am assuming that the bags are still good,, no leaks in them, as it rides fine.
Maybe the pump is faulty, not getting enough air to the left hand side, or it may be something with some valves?, somewhere, I don't know where? Maybe it is just those height adjusters on each corner? How do you adjust those rods? Do you shorten them or lengthen them to raise and lower the height? can you explain in detail?
