Ashley Leach
TryHard South Australia Soarer GT Limited UZZ31 V8
Posts: 392 Reg: 02-2006
| I'm getting some sort of weird transmission noise when I'm in gear. It's a high pitch squealing sound not unlike a cricket. It's only when the car is in gear, throwing it into N or P makes it go away. I've had a look under the car and all I can tell is that it's coming from the trans. Anyone have any idea or similar experiences? Trans mount has been replaced 6 months ago. |
Posts: 6503 Reg: 11-2004
| Are you sure this car hasn't had a thrashing? |
Ashley Leach
Posts: 393 Reg: 02-2006
| Yeah, fairly sure, and I've haven't given it that much. The noise kind of sounds like something rubbing against rubber, maybe something to do with the trans mount again? Why, what are you thinking? I suppose the worst case scenario is that I'll need a new transmission. Even if the car has been thrashed, which I wouldn't think so, I've spent too much on it so far to worry about getting rid of it. I'll just have to get it fixed. |
Posts: 6504 Reg: 11-2004
| The mount just holds the box, so would not be squealing. And yeah, I would do the same |
Ashley Leach
Posts: 394 Reg: 02-2006
| Hmmm, Well I've now got it booked into MV Auto's to check it out, but they can't fit me in until the 12th as they are closed down next week. Hopefully it just needs a service or is something minor fixed. It is possible it's the bearing in the drive train? I've never been really happy with the trans, I've always thought that something would need to be done with it. So I guess if it's dying I'll get a second hand one and shift kit with a tranny cooler. Really the only thing I can do. Hooray another 1k+ I'll be spending on it if I do need a new trans. Fingers crossed I don't. I guess that's what we get for owning Soarer's Peter. I might swing by the shop for a visit on the way back from MV's if that's OK. Figure you need to see the car now. It's so much better than when we had the meet. IF you could run me through putting the braided brake cables on I'd appreciate it. |
Posts: 6505 Reg: 11-2004
| No problem! Always happy to have Soarers visit and the brake lines are easy. |
Ashley Leach
Posts: 396 Reg: 02-2006
| Sweet, I'll email you so you can be ready to be impressed! Mwhahahaha! I did actually find a picture of the drive train assemble all sectioned up with part numbers and the like. It showed a bearing in the center and I remember someone writing that if your trans mount goes it could be putting extra load on the center bearing and that can go. HAHA, found it!
Ashley Leach
Posts: 402 Reg: 02-2006
| So how much would I be up if I have to replace the trans? I'd be looking at an Auto, don't really want to manualise it. |
Anish Varsani
TryHard QLD V8 UZZ30
Posts: 465 Reg: 07-2005
| 2k drive in drive out to do a full rebuild, including valve body mod and torque converter overhaul. Most places don't charge to lift the stall speed because they have to split the converter to inspect and make any repairs regardless. |
David Smith
Newbie Bucklands Beach Soarer TT
Posts: 3 Reg: 11-2006
| Hey guys where do you get that technical info from? those pics with all the part numbers? i have the same noise comeing from my trans it is quite a werd noise i think it is the pump but am prob so far off the ball... lol |
Ashley Leach
Posts: 406 Reg: 02-2006
| I'd probably prefer to drop a second hand box in... how much does one of them go for. You can get all the part numbers from the soarer part numbers CD... if mine ever comes that is... |
Goo Roo Victoria Bog Standard Active
Posts: 1571 Reg: 07-2005
| BTW, nice pic of the TAILSHAFT. That bit goes behind the tranny. |
Ashley Leach
Posts: 408 Reg: 02-2006
| It's part of the drive train assembly and contains the bearing I'm referring too that could be worn. |
Posts: 1581 Reg: 07-2005
| I made the assumption from your first post, when you said it makes a noise in D but not when you put it in P or N, that you were stationary. The centre bearing in the tailshaft will not be rotating when you are stationary (with the exception of a burnout) and as such is unlikely to be making said noise. I'd be more likely looking at the first gear clutch bands in the trans or possibly the torque converter. Does it make the same noise when you are driving?? |
Mark Paddick
Goo Roo ACT UZZ31 V8 Soarer , JZZ30 TT Soarer
Posts: 3039 Reg: 07-2005
| Shift kits can add a little whiney noise to a good tranny but not much. I'd go the 2nd hand 'box but reco'd aren't too bad in price for that extra confidence in it. Shift kit and cooler are a must as I'm sure Mike will let you know. |
Ashley Leach
Posts: 410 Reg: 02-2006
| Dan, yes same noise when I am moving. Really seems to be only after the car warms up. I'm hoping it's something easy (and cheap) to fix. I'll defiantly be going the second hand box with a Stage 1 shift kit and cooler. If that dies, which is shouldn't) I'll look at getting a recond box. Checked trans fluid last night and it's not too far off needing a change. |
Mark Paddick
Posts: 3048 Reg: 07-2005
| I've never heard of it with a Soarer but some cars can be prone to cracking or breaking the flex plate that holds the Torque converter to the crank (all drive goes through it, sometimes called a Drive plate). This can sound something like the end of the World when the crack gets big but is basically easily fixed, just have to pull the 'box out and change the plate. Definitely something to check while the 'box is out. Merc's tend to crack around the mounting bolts for both the converter and the crank. |
Ashley Leach
Posts: 411 Reg: 02-2006
| I guess I'll find out on the 12th. I'll inquire about the shift kit and cooler at the same time I'm there. I'm very interested in one, especially if I can drive it normally as well as have that extra kick when I need it. Stage one it is. Do shift kits cause any extra load on the diff or any other parts? |
Mark Paddick
Posts: 3054 Reg: 07-2005
| Up to a point, yes...and no. If driven hard then, yes the tailshaft, diff and drive shafts will tend to cop a pounding but that shouldn't be all the time and with the newer modified stage 1 kit the changes can still be very smooth if driven that way (this is why I wouldn't buy a 2nd hand shift kit unless I knew it was the later version. The early stage one is harsh ALL the time). For any gain there has to be a cost and at least diffs are easier to change than gearboxes! It seems to be them and not anything else that gives way when pushed. A rebuilt Torsen or similar shouldn't mind too much though. Even a good standard diff will be OK unless you deliberately give it a hard time. Bear in mind that a good standard diff is 15 years or so old now and general wear and tear is going to kill it soon enough unless it gets regular oil and maybe some new bearings and stuff. |
Ashley Leach
Posts: 414 Reg: 02-2006
| I'll only really only be using it to kick people's ass off at the traffic lights and, when I get some rear end noises sorted, maybe a track day or two. I'm sure I'll need to be replacing my diff eventually. I'm just waiting until it dies to get a T2 or something similar. Hoping my transmission isn't dead though, then I'll just get the shift kit and cooler installed. I'd expect some kind of wear though, I mean your changing something to do what it's not designed for. I'll see how I go, with a little luck I could be shift kitted up before Xmas... |
Posts: 1596 Reg: 07-2005
Mark Paddick wrote on Thursday, November 30, 2006 - 12:24 pm:Up to a point, yes...and no.
Nice answer. |
Ashley Leach
Posts: 416 Reg: 02-2006
| Well Mark has been a HUGE help to me the past week. Thanks so much, good to have someone that has such a great knowledge base to draw from. Sometimes I think I don't contribute enough to the forums and I ask too many questions. I have been toying with the idea if a shift kit for almost 9 months now. I look forward to see what it's like when it's on. Just getting a bit ancy about having to wait until the 12th to get that noise looked at. It had to pick the week that MV's are having off... so typical of my Soarer. Just know the right time to start with issues. Like my serpentine belt, thank the lord for belt lube! |
Mark Paddick
Posts: 3069 Reg: 07-2005
| As far as I can tell the shift kit actually reduces gearbox clutch wear by shifting faster. Any increased wear on the drivetrain after the 'box is mostly down to driving style. A standard 'box can destroy a standard diff easily enough as quite a few have proven. The Torsen should be a bit tougher to break just because you gotta spin both wheels and that takes a heap more power but it still does have the same crownwheel and pinion gears to transmit that power. |
Ashley Leach
Posts: 420 Reg: 02-2006
| I Type 2 Torsen center is what I would look at getting. Not that I'll destroy the open spinner any time soon, it will probably die within the year though. Well I'm convinced that a shift kit is what I need! |
Lew Radbourn
Trader Queensland jzz30 ute / uzz30/ 2 X uzz31
Posts: 1573 Reg: 07-2005
| Ashley; head up the MV Automatics at blackwood Mike is over seas until 7th december but when he gets back he can sort it out for you. Some times the planetary gears in the box will make a winy noise. a squeely noise can come from the oil pump . |
Ashley Leach
Posts: 422 Reg: 02-2006
| Yeah, I'm booked in to get sorted on the 12th. I'll have to get them to do a trans service soon as well, don't know when it was done last. |
