Justin Cook
DieHard QLD JZZ30 TT
Posts: 904 Reg: 07-2005
| Hi! Ok I have a manual conversion with the auto ECU. I am getting the ECT error, and the blicking OD light. Is there anyway to stop this? I am guessing its because either the solenoids aren't there, or the speed sensor aint' there. Does anybody know? Can I make up some wizz bang electronic stuff to fool it? I did search too! |
Ben Socratous
Goo Roo SA I am the fibreglass/kevlar/carbonfibre king!
Posts: 1373 Reg: 07-2005
| Get a manual ecu? Take the dash out and remove the O/D lamp? Not as if you need it anymore! |
Goo Roo ACT V8 Ltd manual
Posts: 3050 Reg: 07-2005
| If you find one, let me know please. The OD light does not blink but ECT shows unless I press Scroll or Fuel when it disappears for a while. It makes adjusting the clock a pain, too. |
Justin Cook
Posts: 905 Reg: 07-2005
| Not a bad idea, but the O/D lamp is the diagnostics lamp. I have just read that if you short out the O/D the ECT error doesn't come up. So that is at least half the problem solved. Guess I could wire in a switch for the O/D lamp. |
Andrew Ferres
DieHard WA '86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Posts: 590 Reg: 07-2005
| The O/D light is the diagnostics light for the auto tranny. |
Justin Cook
Posts: 906 Reg: 07-2005
| Nope its diagnostics for everything in my car.... |
Andrew Ferres
Posts: 592 Reg: 07-2005
| So you don't have a Check Engine Light ? |
Justin Cook
Posts: 907 Reg: 07-2005
| Yup but it doesn't flash in diagnostics mode, only the O/D does. But I might have no problems... |
Andrew Ferres
Posts: 593 Reg: 07-2005
| It should give a constant flash if there are no issues. Does it come on with the key ON and motor not running? |
Benjamin Burgess
Goo Roo NSW Toyota Soarer GT-TL, Toyota Corolla Conquest
Posts: 1130 Reg: 07-2005
| Make it so the OD off, so you'll need to bypass that switch. With OD switch on, the auto ecu checks the status of the solenoids. With it off it doesn't. I had the same problem with a suprastick and auto ecu, no longer exists when using a power fc and the suprastick. |
Posts: 3054 Reg: 07-2005
| That is for Justin's TT only, is it not? |
Andrew Ferres
Posts: 594 Reg: 07-2005
Benjamin Burgess wrote on Sunday, March 04, 2007 - 04:08 pm:With OD switch on, the auto ecu checks the status of the solenoids. With it off it doesn't.
With OD off, it still checks the status, but the switch overrides the diagnostics flash. |
Benjamin Burgess
Posts: 1131 Reg: 07-2005
| Are you sure about that? I would have thought it would only check then (when OD is off) when you asked it to, ie short TE1 and E1. My one only checked the status when it wanted to change, not at any other time. |
Andrew Ferres
Posts: 595 Reg: 07-2005
| Ah sorry, I misread what you meant in the previous post. |
Gary Rollason
Newbie Qld TT
Posts: 4 Reg: 05-2007
| Hi All This is now my problem (Thanks Justin!), and it's more an annoyance than anything. Will replacing ECU with a manual one also give me back cruise control? (not working due to manual conversion). Also, is it preferable to get a manual ECU or an aftermarket ECU? What are they worth and how easy to change? Cheers for any help! |
Goo Roo NSW 94 UZZ31 (V8) / 96 JZZ30 (TT) / 97 JZA80 (TT)
Posts: 1837 Reg: 07-2005
| I have a manual ECU if you're interested. |
Gary Rollason
Newbie Qld TT
Posts: 5 Reg: 05-2007
| Vinh PM Sent. Still need to know if this is better option to aftermarket ECU. |
Andrew Ferres
Posts: 666 Reg: 07-2005
| Its a much much cheaper and much much easier option. Whether its a better option or not is purely your call. |
Gary Rollason
Tinkerer Qld TT
Posts: 6 Reg: 05-2007
| Cheers Andrew! Will that give me cruise? |
Andrew Ferres
Posts: 667 Reg: 07-2005
| No idea sorry, you may have to install a clutch switch from the manual model. |
Gary Rollason
Tinkerer Qld TT
Posts: 7 Reg: 05-2007
| Vinh Sent you a PM. Did it come through? |
Posts: 1838 Reg: 07-2005
| Gary, the PM probably went through to my Outlook which I leave open at home. I'm currently at work at the moment, and will check it once I get home |
