  Soarer Central * Transmission * Auto changing to 2nd gear too late Previous Previous    Next Next
Jon Millerchip
Reg: 01-2006
Thursday, July 19, 2007 - 12:12 am, by:  Jon Millerchip (Chip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
In the last week since turning up my boost to 12psi the auto gear box is playing up. When I take off even if I only give it a small amount of throttle it doesnt change gears from 1st to 2nd till about 4000rpm. Other changes are normal and if I change it from 1st to 2nd gear manually it seems to work ok. Any input would be great. Im going to try a ecu reset but I dont know if it will help.
JunkFilterer
Thursday, July 19, 2007 - 04:34 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This may help.
Disconnect battery for 30 minutes.
Start car, then with brakes on, go into each gear for a few seconds, then back to park again.
Matthew Werner
qld
Reg: 12-2006
Sunday, August 12, 2007 - 12:08 pm, by:  Matthew Werner (Matto_888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if that dont work.. pull off your pan and rip your solenoids out and get new ones..
what you described mate is exactly wats going on with mine.. only manual shift doesn help and it doesn change till it goes up nearer the limiter.. that isn't good bye the way
Werner
Jon Millerchip
Reg: 01-2006
Monday, August 13, 2007 - 10:13 am, by:  Jon Millerchip (Chip) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Found out from the mechanic that my second gear is now totally gone, they found bits of the second gear clutch in the pan. So now Im looking for another gear box if anyone has one? Does anyone know if a A341LE box out of a V8 will fit?
Graham Dollisson
GTTL , Morris Marina, P76 V8 Super, P76 6cyl Deluxe
Monday, August 13, 2007 - 10:40 am, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need a TT box.
