  Soarer Central * Transmission * Shift kit installed Previous Previous    Next Next
Aslan Kuyucu
vic
toyota soarer tt
Saturday, September 15, 2007 - 04:46 pm, by:  Aslan Kuyucu (Aslan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just installed shift kit in my tt soarer.
much much better then before just wont to no with you shift kitted tt owner out there is it normal when on part throttle it wont shift as hard as when
on slite throttle . iv found that mine like that
THANKS.....
Blake Gloyn
manawatu
soarer JZZ30 TT
Saturday, September 15, 2007 - 06:11 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"part throttle", and "slight throttle" sound like the same thing. what shift kit do you have? my stage 2 shifts hard all the time. my stage 1.5 is much softer at lower revs, and hard shifting at high revs. MV automatics designed it this way, to improve on the stage 2. Stage 2 is not good for diffs(Violent) and is no longer produced.
Aslan Kuyucu
vic
toyota soarer tt
Sunday, September 16, 2007 - 03:09 pm, by:  Aslan Kuyucu (Aslan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
stage 1 mv shift kit
sorry i mean haft throttle
Celsior UCF11 V8
Sunday, September 16, 2007 - 03:23 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A little more care in writing your messages would be good Aslan. Capitals, correct spelling etc always goes a long way. :-)
Aslan Kuyucu
vic
toyota soarer tt
Sunday, September 16, 2007 - 04:28 pm, by:  Aslan Kuyucu (Aslan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry Mike
Celsior UCF11 V8
Sunday, September 16, 2007 - 04:39 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thats okay, Just here on Soarer Central you will find that you may get more of a response if your messages are more structured and easy to understand. :-)
Sunday, September 16, 2007 - 04:40 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the stage 1 shift kit and it will rip the rear tyres to shreds at half throttle on a short shift into 2nd. Its also firm on light throttle applications..
But i do have the line pressure wound up as much as i can. Which definately improved my 1/4 mile times. And i like it nice and firm on the street too :-)
Aslan Kuyucu
vic
toyota soarer tt
Monday, September 17, 2007 - 06:09 pm, by:  Aslan Kuyucu (Aslan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks Daniel
Luke Nieuwhof
Tuesday, October 02, 2007 - 07:30 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gotta love the chirpies and mini slide into second hehe.
Tuesday, October 02, 2007 - 08:07 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Luke, wheelspin into 2nd on the street if i shift around 7.5k,lol.
Alex Ross
2.5i TT
Reg: 02-2007
Friday, December 07, 2007 - 07:28 pm, by:  Alex Ross (Scoss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys... ive been searching everywhere and i cant find where to buy a shift kit and a stall converter..... help would be awsome...thanks
Friday, December 07, 2007 - 07:42 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Contact Mike at MV Automatics in South Australia... Niall Bond at Bond Auto Tech can do the installation:-) He is located in Botany.
Alex Ross
2.5i TT
Reg: 02-2007
Friday, December 07, 2007 - 11:22 pm, by:  Alex Ross (Scoss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks daniel... any idea of wallet damage??
Saturday, December 08, 2007 - 07:19 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shift kit + fitting is around the $700 mark... I think a Stally is around the $1000 fitted. SO all up your looking at $1600-$1800 i guess.
How long are you going to keep the car? You may as well get the whole gearbox rebuilt which costs $2600 including a convertor. I know its more, but this will handle alot of rwhp!
Shyam Purushothman
Dorkland
2jzgte toyota Soarer
Saturday, December 08, 2007 - 07:41 am, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ive been quoted this for a full rebuild, any thoughts? Is the price about right? Can anything else be done?
Transmission
Replace all frictions with Alto Red Eagle performance plates and upgrade capacity
Fit Koleene steels
Replace all bushes
Mill case flat
Fit deep pan off Toyota truck for more oil capacity
New filter
Replace all gaskets and seals and overhaul kit
Modify valve body
Fit larger ratio boost valve
Flush and test solenoids
Answermatic pressure test trans
Fit custom sealing rings
Fit new sprags to low reverse clutch
Overhaul convertor
And stall to 2500 rpm
Removal and refit is extra
Dyno testing is extra charge
Recommend large oil cooler fitted between $180 to $220 fitted
NZ3260 inc GST
Convertor will be stalled to 1st stage , as much as we can go with the exsisting convertor body
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Saturday, December 08, 2007 - 10:17 am, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel Clarke wrote on Saturday, December 08, 2007 - 07:19 am:
Who's doing the labour in that quote? I went up and saw Mike the other day and fired off a few q's about what to do when the new motor and turbo are in. He quoted (for me dropping off just the gearbox) $810 for a 2800 stally, 1.5 shift kit and new seals/oil!
Anish Varsani
V8 UZZ30
Saturday, December 08, 2007 - 01:34 pm, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fitting shouldn't cost that much. It's only a 1 hour job plus fluid.
Saturday, December 08, 2007 - 05:20 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Morgan was charged about 800 for just the convertor, i was going off that.
If i can get my stally upped to 2800 for under $600 fitted, i would jump straight at it in the new year!
Alex Ross
2.5i TT
Reg: 02-2007
Sunday, December 09, 2007 - 04:03 am, by:  Alex Ross (Scoss) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
HAHA in that case ill call mike and order a stage 1 kit tomorrow.... thanks for the info boys!! much appriciated!
Anish Varsani
V8 UZZ30
Sunday, December 09, 2007 - 09:30 am, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1 hour for the shift kit. I'm not sure about the converter.
Shyam Purushothman
Dorkland
Monday, December 10, 2007 - 11:22 am, by:  Shyam Purushothman (Zulu24) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I take it since there are no references to my quote, that is about all you can do to rebuild and strenghten the gearbox.
Braden Murdoch
Cressida 1JZ TT
Monday, December 10, 2007 - 04:00 pm, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Shift kit is $385 from MV last time I checked.
Fit it yourself at home, all you need is a 10mm socket, (plus rubber mallet, and a piece of wood to prise the tubes off).
Can't remember how much the stallie was, my complete built auto was $2600, and paid a mate $200 to fit it.
Lew Radbourn
Queensland / Gold coast
jzs147 93 TT / uzz30 93'/ 2 X uzz31 92' s
Monday, December 10, 2007 - 07:58 pm, by:  Lew Radbourn (Marlew) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
BUT if you fit it your self DON'T forget to send your old valve body back to MV's
Benjamin Burgess
Toyota Soarer GT-TL, Toyota Corolla Conquest
Thursday, December 13, 2007 - 04:42 pm, by:  Benjamin Burgess (Jampac) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got my stallie done for 380 for the converter itself exchange and was about 80 bucks or so to fit it.
