Tuesday, November 13, 2007 - 11:07 pm, by: Cihan Aday(Cihan)
I've spoken to David RE the auto box rebuilds and he can't be sure it'll hold 340rwkw+, not because he doesn't know what he's doing but because he hasn't tested the physical limitations of the box. From what i could gather he CBF devoting some of the time/effort/research from the several sub 10 second XR6 T builds he's working on to A series Toyota transmissions.
Generic shift kits are easy, because they're well... generic. There's nothing MV does thats *special* there. A few differences between how they achieve the desired result (different valves modified to differing extents), a few different parts (AFAIK accumulator springs) maybe but still the same concept.
In regards to complete A series rebuilds though, they've spent a lot of time and money on Shanes transmission which has quite clearly paid dividends in the long term. Kudos to them for making it happen.
Friday, November 16, 2007 - 11:38 am, by: Braden Murdoch(Ribfeast)
MV Automatics is 08 8370 0430 They can build you a box good for 500rwkw. Bargain considering it is $2600, including 1.5 shift kit and 2800 stallie (with lockup). The 1.5 shift kit is pretty harsh compared to the stage 1, be warned ;)
Mine was fitted last Fri but failed due to some teflon ring/seal, and they are fixing it under warranty at a local place. Should be OK to pickup this afternoon and I'll update you on what I think of it.
Monday, November 19, 2007 - 03:27 pm, by: Braden Murdoch(Ribfeast)
Picked up the auto on Fri afternoon, the gits who put it back together may not have done it right, makes a clicking noise as you drive along grrrr Drives fine though and does everything it should do properly. Very strange to drive with the stallie!
Tuesday, November 20, 2007 - 06:50 pm, by: Luciano Fuentes(Luch)
got my box back paid $3200 thats for full upgrade 3800 histall with lock up 1.5 shiftkit and tranny cooler so far verry happy cant wait to see how it runs
Wednesday, November 21, 2007 - 10:37 am, by: Shane Crichton(1jz747)
my box is now for sale, iam going to a powergilde as i am taking the road rego off the car and going to slicks.
mike is pulling it apart and putting new clutches in it, new bands etc in it. so it will be a brand new box again it will come with 3400 stall and shift kit which retails for around $3400 together
i am hapy with $3000 and buyer pays freight. its in the forsale section.
