  Soarer Central * Transmission * B&M pro ratchet shifter to the tt gbox as mine is having problems Previous Previous    Next Next
James Brodie
Soarer v8
Monday, November 26, 2007 - 07:09 pm, by:  James Brodie (Soarer987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
gidday
i fitted a b&m pro ratchet shifter the the 1jz and auto in my vl commodore and im running into problems with the shift.
if i pull the shifter back to the first position and the gbox automaticly changes from 1st to 2nd and then will hold second till i change the shifter position.
in my v8 soarer if i shift the shifter to 1st it will rev all the way till i shift it.
has anyone run into the same problem with there gbox or could it be a wring problem in the box or a problem with the box??
i just need some ideas on what could be wrong.
any help would be great.
Monday, November 26, 2007 - 07:34 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You SURE you are in 1st gear ?
You may have it in 2nd !
Monday, November 26, 2007 - 07:55 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
IM with Neil... SOunds like your onyl getting into 2Nd as this will lock it in 2nd gear even from a stand still.
James Brodie
Soarer v8
Monday, November 26, 2007 - 10:46 pm, by:  James Brodie (Soarer987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thats what i thought so i disconnected the shifter cable and manualy moved the selector on the side of the box as far back as it would go.
and still no luck.
when it shifts into second then you get of the accellerator then the box will go back to first and nearly send you through the windscreen.
the box dose have a mv 1.5 shft kit and a 3500 stall in it too if that makes any difference.
Tuesday, November 27, 2007 - 06:13 am, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just instal one of MV's Shift Control boxes :-)
James Brodie
Soarer v8
Tuesday, November 27, 2007 - 08:04 am, by:  James Brodie (Soarer987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what are they neil??
Tuesday, November 27, 2007 - 08:38 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Call Mike and he will reveal all:-)
Christian Molenda
T
Friday, November 30, 2007 - 11:04 am, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah it doesnt sound like a problem with the B&M. I have a b&m in mine and it works fine
Luciano Fuentes
vic
tt
Friday, November 30, 2007 - 03:48 pm, by:  Luciano Fuentes (Luch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey have you guys got a pic with b&m shifter i want to get one but unsure what it looks like. do you remove the console etc
James Brodie
Soarer v8
Monday, December 03, 2007 - 06:59 pm, by:  James Brodie (Soarer987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i spoke to mike today and found out about the shift box. im going to get it but we need to find out if the gbox is shifting because of hydrulic pressure or if the ecu is wired incorrectly.
mike said that i have to put my test light on the s1 and s2 wires of the auto at the ecu and see if the ecu is working correctly.
i need to find these wires at the ecu. dose any one know where to start looking??
the b&m is in a vl not a soarer i have the 1jz in the vl.
Braden Murdoch
Cressida 1JZ TT
Wednesday, December 05, 2007 - 10:27 am, by:  Braden Murdoch (Ribfeast) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have a look on Toymods in the wiring diagrams section, I posted up a few Soarer ECU pinouts there.
James Brodie
Soarer v8
Sunday, December 30, 2007 - 01:18 pm, by:  James Brodie (Soarer987) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i finaly checked the ecu and its doing every thing perfictly.
mike reckons that it may be a wiring issue through the neutral start switch.
Michael Keen
soarer tt
Reg: 10-2007
Tuesday, March 04, 2008 - 05:49 am, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
got any pics of a b&m installed in soarer people?
Christian Molenda
T
Wednesday, March 05, 2008 - 01:55 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Michael Keen wrote on Tuesday, March 04, 2008 - 05:49 am:
I have posted pics up on here before. a search should find it
