  Soarer Central * Transmission * Over Drive----- what speed do you guys use the over drive at? Previous Previous    Next Next
Open in new windowArchive through October 21, 2005Don Bagnall20
Sam Sulley
GT-TL
Sunday, October 23, 2005 - 12:40 pm, by:  Sam Sulley (Ss666x) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
lol, i don't really use it except on highways. i shift it like a manual, 70 kays an hour i shift to second, 120 i shift the third, 160 press the button and then let it slowly slow down so i can cruise control at 108kph. I love jap laws
serious though, i leave mine on most of the time. In PWR as well :-)
Ben James
Queenland
Twin Turbo : )
Sunday, October 23, 2005 - 02:16 pm, by:  Ben James (Silverbullet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm confused should it be on or off ? when I switch it on it seems to lose power or slow down with a grinding noise, and then back to normal, does it save more fuel with overdrive off, or on ?, and is there more performance with it on ? also when switched on, above 80km does it engage 4th gear ?, because I usually drive with mine off, even on the highway going 110km, so does that mean I'm still stuck in 3rd gear with it off ?
Graham Dollisson
GT-TL
Sunday, October 23, 2005 - 03:45 pm, by:  Graham Dollisson (Alloyvee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
od is 4th gear!! Yes, you have been driving around in 3rd with it off.
Clayton Webb
'31 V8
Sunday, October 23, 2005 - 05:42 pm, by:  Clayton Webb (Clackers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
On 24/7. I just take it off when going down hills or
a there is a group of Buzz box cars on the side of the road. Sounds nice when it changes down!
Sunday, October 23, 2005 - 06:31 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pretty much like Clayton. It is an automatic gearbox and OD is just 4th in it, nothing more. I change down for engine braking or occasionally to get a little more response when I do not want to press hard enough for kickdown.
Note to Ben from his Great Aunty Dorothy: for better fuel economy on the freeway, try changing into top gear...
Sunday, October 23, 2005 - 06:32 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
...although, I am a little concerned about that "grinding noise". Nothing like that is expected. In top the gearbox should be smooth and quiet. Who does the mechanicals on your car?
Ben James
Queenland
Twin Turbo : )
Sunday, October 23, 2005 - 11:00 pm, by:  Ben James (Silverbullet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
no its not a bad noise, its just there for a second ,when overdrive is switch on, obviously at the wrong time, so Im better to use it after 80km an hour ? unless it was on from the start ?
Monday, October 24, 2005 - 02:21 am, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben, if you want to save a bit of fuel you can put it on any time you like. It's purely a question of economy and driving style.
Lincoln Carter
GT Limited
Monday, October 24, 2005 - 03:34 pm, by:  Lincoln Carter (Dex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
on all the time (ie O/D off displayed)would think they would have a light for when its on not off... but anyways, soemtimes use it for breaking. gotta save that fuel.
Steve Nolan
SC400 Ltd (31)
Monday, October 24, 2005 - 04:40 pm, by:  Steve Nolan (Hiddenvision) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh golly,
Leave the button alone and play with the passenger instead.
Except on long downhills, then it is not safe to fiddle with the passengers buttons and best to play with you own.
The Light To show it is OFF is good as the normal position is on (thus no distracting light)
When should I use my sports / Normal Switch ?
Hayley Rafati
Monday, October 24, 2005 - 05:56 pm, by:  Hayley Rafati (Hayley) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok so overdrive is forth? Overdrive on = more fuel efficient true?
Play with the Passenger? What does that mean exactly?
Monday, October 24, 2005 - 11:26 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I drive mine in sports/pwr mode always. It kicks down earlier and holds revs longer (it also uses more petrol but it's more fun).
The last button is the tems sport/normal which is for the suspension. You use it on smooth roads or when you want to get around corners quickly.
It stiffens up the suspension. Try playing with it (the button, not your passenger) on the motorway and you will feel the difference immediately.
Bernie Juckers
Tuesday, October 25, 2005 - 11:14 am, by:  Bernie Juckers (Burn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have always believed that because the ratios in overdrive are so high, it puts more strain on your engine and components if you use it at low speed around the city. Correct me if I'm wrong.
JunkFilterer
Tuesday, October 25, 2005 - 11:27 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Bernie, firstly at low speeds the torque converter allows the engine to rev at a comfortable level while making the torque required to move the car. Second, the smarts decide if it needs to go down another gear or not.
If you try too high a gear in a manual, it will judder quite noticeably, something you won't experience with the automatic.
Manuals don't have the "give" of a torque converter, nor the smarts to manage the gearbox.
Tuesday, October 25, 2005 - 11:27 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Less effective torque through the system in a higher gear means less stress on the driveline , not more. As for the engine, you have an automatic gearbox and it will change down whenever it feels the need. Leaving overdrive on reduces stress rather than raising it. High revs kill engines, not low.
The ratio in overdrive is not "so high", it is a standard 4th gear and should be treated as such.
Bernie Juckers
Wednesday, October 26, 2005 - 11:05 am, by:  Bernie Juckers (Burn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I stand corrected, thanks guys.
