Monday, December 24, 2007 - 08:22 pm, by: Luke Cairns(Soarer350)
i have a 91 soarer auto with a gt3540 turbo and all the trimmings i make 350rwkw, i have had the auto built up and it has a 3500 stally, stage 2 shift kit and i have fitted a oil cooler but it still seems to heat up quite alot is there anything i can do to fix this
Monday, December 24, 2007 - 10:18 pm, by: Charlie Ters(Ul05st)
themo fan on the cooler, when the car triggers the brake, the relay actvates and cools the cooler when car is slowing/stopped, an even better way will be as delayed switch off around 3 secs, to stop unecessary swtiching while still moving.....this trick works on 10 sec cars...
Thursday, December 27, 2007 - 03:06 pm, by: Braden Murdoch(Ribfeast)
Make sure the cooler is bolted to the radiator itself, so air is forced to travel through it. Made a big difference for me. Does your stally have a lockup clutch still? My built auto gets toasty hot fairly quickly with the stallie, you can't be up it all the time if you want the auto to last. Better off getting a manual if you like to drive it hard round town ;)
