  Soarer Central * Transmission * Dexron 2 or Dexron 3? Previous Previous    Next Next
Anish Varsani
V8 UZZ30
Friday, October 28, 2005 - 10:15 am, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got a shift kit on order. I flushed my transmission a few months with 12L of T-IV. When I drain the sump to bolt on the shift kit, can i top up the pan with Dexron?
If so, which is more suited to soarer boxes, Dex2 or Dex3?
thanks.
Ben Williams
none
Friday, October 28, 2005 - 10:20 am, by:  Ben Williams (Benzini) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe now that you have a shiftkit it's best to use Dex 3. If you didn't have a shift kit Type IV would be recommended.
I'm sure someone here with more knowledge than me will confirm...
Super Charged UZZ31
Friday, October 28, 2005 - 06:14 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You can stay with the T-IV or switch to Dex3, choice is yours now :-)
