Rating: N/AVotes: 0 (Vote!)
Ben Lipman wrote on Wednesday, May 14, 2008 - 08:18 pm:Are your gearbox/engine mounts in good nick? Could the engine/gearbox be moving around under heavy braking? Is there anything fouling the shifter in the upper three positions?
Andrew Meiers wrote on Wednesday, May 14, 2008 - 07:59 pm:Does the shifter have any contact with the plastic gear boot trim when changing gears? Does it hit the trim?
Mustafa Akgul wrote on Wednesday, May 14, 2008 - 11:05 pm:do you have a short shifter in it ? if you do thats why its probably hitting the plastic trim wich could be causing it to pop out of gear. I modified mine so it doesnt hit anymore.
