Monday, May 19, 2008 - 07:08 pm, by: Marcin Kurek(Blk747)
hey guys i have a 1993 soarer tt and teh auto for some reason when im full throttle shifts at 4500 - 5000 but not always just some times it will shift way to early and sometimes it will actually shift at 6800 - 7000, this is in Drive not in manual mode so has anyone got any ideas? i have no warnings or anything like that
Tuesday, May 20, 2008 - 10:35 am, by: Blake Gloyn(Blakenz)
does the car run poorly sometimes and wont idle? if so, your 02 sensor has wires inside it that are intermittently touching and causing problems. mine did this, and the box wouldn't rev past about 4500rpm before changing gear. No one knew why. My auto electrician found the fault,replaced the sensor and gear changes returned to normal.
