  Soarer Central * Transmission * ECT and O/D not working... aaarrrggghhhhh!! Previous Previous    Next Next
Nye Phillips
montpellier
2.5 tt
Reg: 06-2008
Tuesday, September 30, 2008 - 04:48 am, by:  Nye Phillips (Nye) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys (n galls) I have sorted out the aircon problem at last, I bought a dryer, and 2 valves and converted to the new gas and bingo, ice cold air!
But i really need help with my ECT and O/D - they don’t work! I have a car that is permanently in power mode and I would love to just cruise now and then.
After 1 mile from cold the ECT warning starts flashing and stays on until I restart the engine then 1 mile and off it goes again, the power switch does nothing and the O/D is also inactive.
I cannot do the diagnostics recommended by other threads because I need the O/D switch to be working first, I have spent all day on this forum looking for answers – no luck, please chaps, I am at the end of me tether!!!
Nye Phillips
Montpellier France
2.5 TT
Reg: 06-2008
Tuesday, September 30, 2008 - 04:54 pm, by:  Nye Phillips (Nye) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi there, is there anybody out there??
Tuesday, September 30, 2008 - 05:09 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah.
Nye Phillips
Montpellier France
2.5 TT
Reg: 06-2008
Tuesday, September 30, 2008 - 08:24 pm, by:  Nye Phillips (Nye) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thank you for responding Peter, any ideas?
Chris Papas
Reg: 11-2006
Tuesday, September 30, 2008 - 09:11 pm, by:  Chris Papas (Papasc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nye, have a similar problem with the O/D either not working properly or ECT flashing.
My local auto mechanic managed to put a probe on and the solenoid has died. Replacing tomorrow.
The symptom originally was O/D would not dis-engage . Never a problem in getting O/D on, was when I wanted to slow down using the gears that it would take for ever to come on, and even then it was too sporadic. It seems the solenoid was on its way out.
Hope that helps.
Nye Phillips
Montpellier France
2.5 TT
Reg: 06-2008
Wednesday, October 01, 2008 - 12:06 am, by:  Nye Phillips (Nye) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thank you for your information Chris, I hope it works for you. My problem is that neither the switches are responding, it could just be a fuse somewhere but I have searched the forum and cannot find any information to tell me what/where the fuse might be!
I have checked the wires to the o/d button and they are dead.
I have spent 4hrs on it this morning and it seems I am still at square one - very frustrating!
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Wednesday, October 01, 2008 - 06:33 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The wires at the OD button will be dead, as the globe is in the circuit before them.
Are you sure the globe isn't blown?
One wire to the globe should have +12v when ever the key is ON. Pull the dash out and verify that.
The OD OFF button overrides the ECU's control over the globe, so regardless of the ECU the light should be on with the button out and the key ON.
