Tuesday, January 27, 2009 - 10:38 am, by: Terry Forde(Ter)
Hey guys, Went to pull out the EMV & failed at the first step! The red button depresses OK, but I can't get the gear column to budge. Am I missing something really simple here or is this a bigger issue?
Tuesday, January 27, 2009 - 10:59 am, by: Terry Forde(Ter)
Michael James wrote on Tuesday, January 27, 2009 - 10:48 am:
Did you press the button on top of the gear level as well?
Unfortunately, yes. I put a fair bit of pressure on both buttons, but it doesn't give at all. I was expecting it to move as easily as when the engine is on.
Tuesday, January 27, 2009 - 12:42 pm, by: Terry Forde(Ter)
Dave Rose wrote on Tuesday, January 27, 2009 - 12:01 pm:
You need the ingition on when you press brake to activate the gear select .
Ahh. So are you saying the sequence is to have the ignition on, depress brake, move gear lever into neutral, press red button & turn off ignition? Or, have ignition on, depress brake, turn off ignition & move gear lever to neutral using red button?
Saturday, January 31, 2009 - 08:28 am, by: Robert Davies(Blueone)
The red button pushes a plastic Tag which is mounted to a very weak piece of tin, they can bend out of shape very easily and then thats all it will be I reckon.
Sunday, February 01, 2009 - 08:20 am, by: Robert Davies(Blueone)
Shane Haverkamp wrote on Saturday, January 31, 2009 - 11:40 am:
i didn't think you'd be able to take the console trim off with out having the gear lever in neatural anyway.
how would you be able to pull down the bit of plastic on its base to access the screw that holds it on?
is there any reason why you cant turn the ignition on to move the gear lever?
Thats all you do, move it to neutral with the ignition on, remove 2 screws, remove shifter, remove plastic surround. Make sure red button is pressing lever.
Thursday, February 05, 2009 - 12:00 pm, by: Terry Forde(Ter)
Robert Davies wrote on Sunday, February 01, 2009 - 08:20 am:
Thats all you do, move it to neutral with the ignition on, remove 2 screws, remove shifter, remove plastic surround. Make sure red button is pressing lever. :-)
Yeah, that's the go! Fix that first & then I'll be able to mess with the electrics. Cheers.
