Wednesday, March 25, 2009 - 08:22 pm, by: Ben Ramoss(Ijzzzz)
Hi im in the middle of installing a suprastick and am having trouble with Second and third gear (both which need solenoid 2 to power up.) I have got lights installed to indicate when either solenoid get power and so it is showing me that the suprastick is working correctly but the trans does not change into 2nd gear. The light shows that there is power but still no change, I even ran a direct wire bypassing the trans ecu and the solenoid still did not click on. This is showing me that S2 is faulty, could there be anything else? The car shifted fine before i installed the Suprastick. Gear 2 doesnt work as it requires solenoid 2 to be powered, and 3rd gear doesnt work as it requires both S1 and S2 to be powered. Is there any other test I can do before removing the tranny sump to check the solenoid? Do the solenoids play up often? Cheers
