  Soarer Central * Transmission * B&M Shifter questions Previous Previous    Next Next
Open in new windowArchive through April 30, 2011Matthew Crawford25
Sebastian Grant
soarer TT
Reg: 01-2008
Sunday, May 01, 2011 - 06:41 am, by:  Sebastian Grant (Saabg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So you ratchet 1,2,3 then press a button to go to 4?
Matthew Crawford
JZA80 T88-38GK @630hp
Sunday, May 01, 2011 - 07:38 am, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yep, same setup as stock really
The switch just cuts power to solenoid 2 for OD activation,
I have a latching switch for TC lockup, only really used when cruising or on the dyno.
Aaron Mead
Sunday, May 01, 2011 - 12:20 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does your OD switch disengage automatically if you ratchet back to 2nd/1st? Im trying to wire mine up somehow to avoid third gear take offs :-(
Matthew Crawford
Sunday, May 01, 2011 - 06:51 pm, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No, it's just a switch on the dash - I only ever touch it when i'm cruising (which isn't often with over 450kw)
Sunday, May 01, 2011 - 07:23 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have one of Cams switchable shift boxes . I didnt bother wiring up overdrive as i only use it on the dyno and track . However i just have a toggle switch for the convertor lockup when in manual mode .
Sebastian Grant
soarer TT
Reg: 01-2008
Friday, June 24, 2011 - 10:41 pm, by:  Sebastian Grant (Saabg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Any updates?
Sebastian Grant
soarer TT
Reg: 01-2008
Friday, July 29, 2011 - 07:03 am, by:  Sebastian Grant (Saabg) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I spoke to someone at mv automatics yesterday and he said that I don't need a manual valve body. He said that I just need the mv shift box. Is this correct when I want to go full manual as I'm running a power fc?
