  Soarer Central * Transmission * WTF is this??? Previous Previous    Next Next
Auckland
UZZ31 Soarer
Reg: 03-2009
Sunday, May 24, 2009 - 02:23 pm, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
30-41LE Bolt yoke automatic transmission? I am about to purchase a engine and this comes with it. Please can any one shed some light?
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Sunday, May 24, 2009 - 05:09 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im assuming its the yoke out of the transmission for the driveshaft, aka mates to the splines of the output shaft of the transmission and is attatched to the first section of the driveshaft via a universal.
Dont hold me to it though, but that is what i would assume it is
Auckland
UZZ31 Soarer
Reg: 03-2009
Sunday, May 24, 2009 - 06:44 pm, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I should be more specific..... Is this a standard trans? What is it out of?
Aaron Mead
Sunday, May 24, 2009 - 07:40 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A341LE, also known as A30-41LE. Found behind jzx100 chasers and USDM spec Ls400's, Sc400's not sure what the JDM version is called, probably A341le. Its a 4 speed.
Aaron Mead
Sunday, May 24, 2009 - 07:44 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The difference is that one term is used as the Aisin manufactures code (the company that makes the transmissions for Toyota and Lexus. Toyota actually own a massive chunk of Aisin, who also make boxes for heaps of other manufacturers) and the other is the toyota code- I think A341LE is the toyo code, and A3041LE is the Aisin code.
Auckland
UZZ31 Soarer
Reg: 03-2009
Sunday, May 24, 2009 - 07:51 pm, by:  James Johnson (Jimbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ah huh that's great thanks, just what I wanted to know.
