  Soarer Central * Transmission * 1st to 2nd slipping badly, trouble diagnosing Previous Previous    Next Next
Geoff McHeyzer
Reg: 07-2008
Monday, July 13, 2009 - 10:53 am, by:  Geoff McHeyzer (Cheesegrinder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey all,
Im having problems with my shifting between 1st and 2nd gears. I took it in to get serviced and the guys there couldnt get any feedback from my computer to diagnose the problem. They said the gearbox looked in good cond, then said it was prob the ECU.
The problem seems to go away if i shift gears myself but if leave it in drive it slips until i let off the gas, then it changes.
Any ideas on what it could be?
Justin Hughes
2.5 GT-T JZZ-30 212rwkw @ 15 psi
Tuesday, July 14, 2009 - 01:19 am, by:  Justin Hughes (Juzza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Solenoid/s ....
.... run the diagnostics ....
http://soarercentral.com/sc-forum/messages/1113/932.html#diag1
.... then call MV Autos for a replacement ... 08 8370 0430
