Monday, January 18, 2010 - 12:45 am, by: Dixon Won(Covert_operator)
Need the help of all the gurus here.
I wish to put an A340E off a jza80 into my soarer. I understand I will need to swap the valve body from the soarer box into the one off the supra and hook up line pressure cable.
How do I go about hooking the cable up? Is there a place for the cable on the supra box already?
In addition, I need to acquire the torque converter and flexplate as well. Does this become a bolt on affair with all that?
Monday, January 18, 2010 - 07:41 am, by: Blake Gloyn(Blakenz)
make sure you get the 2jz bellhousing,just in case it is of a different "depth" than the 1jz. There is no hole for the cable on the jza80 box, but there is a place to make that hole,if you understand me. i'm not sure what to do with the electrical plugs though.. the output shaft is different from memory(a 4 bolt flange rather than a sliding spline)so the driveshaft needs adapting. I have read of one guy who used the 2jz internals and put them into the earlier box, thereby retaining the factory tail end on the gearbox and electrical plugs. You would want someone v. experienced with the toyota a340 gearbox before you attempted this though.
Monday, January 18, 2010 - 05:29 pm, by: Lew Radbourn(Marlew)
Dixon; If you get the supra box Make sure you have the torque convertor and the drive plate and the bolts to couple them both together.(thay are larger than the 1jz ones) then put it all in the car You will also need to change you valve body over from the 1jz box and fit it to the 2jz box there is an extra solinoid in the 2jz box that isn't in the 1jz. when you have done this mate Happy days
Tuesday, February 09, 2010 - 04:05 pm, by: Lew Radbourn(Marlew)
Chris grab the front section of the drive shaft to suit the 2jz box. the solinoids will be the same as the 1jz as you will be fitting the 1jz valve body in the 2jz box as well. hahahahhaha thats fine mate if i am around i am more than happy to advise what i have done several times before ...My little van has a 2jz box with a 1jz valve body in it. so exactly what i am explaining for you to do is exactly what the little van has in it already.
