  Soarer Central * Transmission * Weak accleration with Overdrive on. Previous Previous    Next Next
Ou-yang Liang Qing
Melbourne
Reg: 04-2010
Tuesday, April 06, 2010 - 01:57 pm, by:  Ou-yang Liang Qing (Raphael_86) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My 91 soarer have this issue of a weak acceleration with overdrive on, thus i normally leave it off and its fine. My Mechanic told me that it was the solenoid issue and if i wanted to resolve it, the solenoid would have to be replaced.
Anyone knows about this issue or have similar issues and knows the pricing of the solenoid?
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, April 06, 2010 - 07:51 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If it is the solenoid that is causing the problem a complete set of solenoids is about $180, I'm not sure if they can be purchased individually.
Other problems can be wire harness splits, and bad ground or solder joint on the solenoid causing it not to work.
