  Soarer Central * Transmission * Gearbox wont leave Park Previous Previous    Next Next
Matthew Hamilton
HKS Single Turbo Soarer
Reg: 12-2006
Saturday, April 17, 2010 - 05:53 pm, by:  Matthew Hamilton (Matthamilton) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Car has been laid up for about 6 months to a year since I canned everything and we started her up today.
So far:
- Starts and idles fine
- All diagnostics are clear
- The car will not shift out of Park
Tested:
- Override switch / No change
- ECU Reset / No change
- Gearbox ecu reset / No change
The shifter seems physically locked into place, I get the feeling there is some kind of lock out solenoid that is causing me problems here.
Anyone have an idea on what could be causing the issue?
Matthew Hamilton
Reg: 12-2006
Saturday, April 17, 2010 - 05:56 pm, by:  Matthew Hamilton (Matthamilton) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Also;
- The break lights are fine, so that isn't stopping it.
- The te1 - e1 diagnostic check isn't showing a fault code.
Costa Tsimiklis
386.2 rwkw Soon T51R or GT4094 :-O
Reg: 07-2008
Sunday, April 18, 2010 - 02:56 am, by:  Costa Tsimiklis (Driftshop) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Very strange. Have you tried pressing the red button to manually disengage? I'm pretty sure its red, its a small button with Jap writing on it. Could be a black button. Its near the PRND section at the top.
Solenoid could be faulty - take the surround out and see if it moves?
