  Soarer Central * Transmission * URGENT INFORMATION REQUIRED! Previous Previous    Next Next
Ben Evans
Monday, December 12, 2005 - 12:53 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When i bought the car, it came with another auto and torque convertor. I assumed it was a TT A340.
I have taken the torque convertor to a guy to get it rebuilt and strengthened but he said its a V8 convertor! as the TT one is smaller!
Is the V8 A340 box the same as the TT one? IE: if i swap the bellhousing over from my stuffed TT auto to the spare V8 box, will it all bolt up?
And fit on the 1J?
Also, is there any difference in the shift kit i have in the TT as i want to swap that over as well...?
If they are different, then i will have to buy another TT auto, which i cant really afford, so anyone want to swap?
There is no stickers on the auto, they've rubbed off.
Thanks heaps
Ben
PS- this is fairly urgent ass i need to let the guy know what i want done.
Ben Evans
Monday, December 12, 2005 - 08:38 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the model number on the box in the car says:
3040LE
the model on the box i want to swap in is
3041LE
Obviously theres a model difference, but are they interchangeable?
Thanks
Ben
Ben Vandie
JZA80 Supra
Tuesday, December 13, 2005 - 08:19 am, by:  Ben Vandie (Vandie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was under the impression the V8 auto had electronically controlled line pressure, where as the TT has direct throttle controlled line pressure. Please, correct me if I am wrong people.
Ben Evans
Tuesday, December 13, 2005 - 10:28 am, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
help peoples! i need info ASAP!
thanks
Ben
Damien Smith
Manual UZZ31
Tuesday, December 13, 2005 - 12:16 pm, by:  Damien Smith (Damien) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Vandie wrote on Tuesday, December 13, 2005 - 08:19 am:
The earlier model V8's had a cable controlled line pressure. Don't know about your other questions though.
Chris Davey
Corona
Tuesday, December 13, 2005 - 12:43 pm, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
AFAIK the A3041LE was used behind jzx81 Chasers so to me that says that it will be the same as the v8 one and you will be able to use it. Why not just try and bolt the bell housing on and see if it fits. Check the plugs to the auto are the same and the kick down cable is same and then whack it in. I thought all valve bodies are the same with the 340e variants. Why not give Mike at MV a call as I am sure he will have definite answers to your questions.
Ben Evans
Tuesday, December 13, 2005 - 07:41 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yep, called him and its completely different! damit.
I cant even bolt the bellhousing on. The ECU wont talk to the v8 box as its from a cressida apparently.
Well look like i need a TT box, anyone know where to get one?
Ben Evans
Wednesday, December 21, 2005 - 09:04 pm, by:  Ben Evans (Sbyder) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
UPDATE!
Can someone please check their JZZ30 soarer and see if the auto is a 3041LE model?
I have found an old chaser with a 1J and the same model box!
If you find that your soarer has a 3041LE box then it will save me a LOT of money :-)
Thanks peoples!
Ben}
