1
3
7
Days
Search
Topics
Tree View
Help
Soarer Central
Transmission
Possible to drive without shifter?
Previous
Next
Author
Message
Jason Cheah
JZZ31 no more... JZA31?
Rating: N/A
Votes: 0 (
Vote!
Tuesday, August 10, 2010 - 11:53 pm, by:
Jason Cheah
(Freaky)
Gonna be recovering my shifter soon.
Is there any way of driving the car other than having a spare shifter?
Ali Saeed
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 12:03 am, by:
Ali Saeed
(Ali)
you can drive without a shifter, as you can still press the button to move it..
Jason Cheah
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 12:06 am, by:
Jason Cheah
(Freaky)
But no overdrive right?
Ali Saeed
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 12:52 am, by:
Ali Saeed
(Ali)
yeh no overdrive. just leave OD on when you take it off, or remove the OD switch from the shifter. they wont need it and it is removable via a flat blade screwdriver.
Jason Cheah
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 10:22 am, by:
Jason Cheah
(Freaky)
Thanks Ali.
So I presume the car will be on the last known setting?
Ali Saeed
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 04:37 pm, by:
Ali Saeed
(Ali)
never tried it, but pretty sure it will be
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Rating: N/A
Votes: 0 (
Vote!
Wednesday, August 11, 2010 - 05:46 pm, by:
Boris Siljanoski
(Z2tt)
You can drive the car without a shifter handle, you just press the plastic button downward to use the shifter, be sure to wipe the grease off it.
Overdrive can still work as you will have the two wires present for the switch.
Wires joined = Overdrive Off
Wires Not joined = Overdrive On.
By joining or separating the two wires, you are basically carrying out the function that the overdrive switch does.
-Color-
Black
Red
Green
Blue
Yellow
Purple
Orange
Cyan
Gray
White
-Font-
Arial
Courier
Symbol
Times
Verdana
-Size-
Smallest (-2)
Small (-1)
Normal
Large (+1)
Largest (+2)
Username:
Important Posting Information:
Administration
Log Out
Previous
Next
