  Soarer Central * Transmission * Manual Conversion Previous Previous    Next Next
Open in new windowArchive through December 09, 2010Bernard Smith-Robert25
Bernard Smith-Roberts
Soarer V8
Reg: 08-2008
Thursday, December 09, 2010 - 11:28 am, by:  Bernard Smith-Roberts (Gaze) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
By dash I meant cluster.
Aaron Casey
Thursday, December 09, 2010 - 12:28 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the pedal box requires 3 drill holes... 2 for the clutch master cylinder. and one for the bottom left bracket bolt near the heater unit.
1st conversion took me about 3 weeks just cause where it was and was doing other stuff at the same time.
the second one i done it took me 3-4 hrs and even had to do some custom modifying to get the gearbox mount to fit as was out of the jza70..
to run the standard clutch line you install it while you have the gearbox out and clip it into the firewall clips from underneath... easy as. no way would i try with gearbox in.
you have to cut a small portion of trans tunnel out for the shifter (91-93, i havent done a remote style so not sure bout that) this is sitting in front of where the auto shifter goes through and is basically marked out and slightly raised section. then make a small metal plate to cover the original hole from the auto shifter.
and for costa's defence when in a workshop it would take bit longer as you usually get randoms turning up and having to help them out. and also the time to take the one out aswell.
as a hard job to convert a 1jz id say it was actually quite easy but there is a chance to stuff it up bad... and not do a decent job.
Orton Marchant
NSW Blacktown
Reg: 01-2011
Monday, February 21, 2011 - 05:20 pm, by:  Orton Marchant (Mythorite) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can someone enlighten me between the differences between remote and i guess a non remote tranny? sorry for crashing the thread.
Tony Nguyen
Reg: 09-2008
Monday, February 21, 2011 - 05:39 pm, by:  Tony Nguyen (Blade4546) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's just the positioning of the shifter. Remote shifter sits back more from the shifter input and the shift throw is shorter whereas the non remote goes straight in and has a longer shift throw
Orton Marchant
NSW Blacktown
Reg: 01-2011
Tuesday, March 01, 2011 - 10:02 pm, by:  Orton Marchant (Mythorite) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
oh okay, so its like a short shifter?
Nathan Richardson
N.T.
UZZ32 #445 (V8 Supercherged 5Speed. 291RWKW)
Sunday, March 27, 2011 - 10:35 pm, by:  Nathan Richardson (Richtheblack) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Orton Marchant wrote on Tuesday, March 01, 2011 - 10:02 pm:
No it's not. A remote shifter sits on a bracket away from the box and basically that is it. it doesn't mean the shift will be shorter or not.
