  Soarer Central * Transmission * MV Autos Shift Kit Previous Previous    Next Next
Peter Horniak
Tokyo-Shi
Reg: 07-2006
Monday, March 21, 2011 - 10:52 pm, by:  Peter Horniak (Poida) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys,
Just a quick question.. Was just wondering how much you all paid for your shift kits?
1 and 1.5? And did you have to send your valve body back down to him?
He doesn't give a discount for Soarer Central members at all does he?
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Tuesday, March 22, 2011 - 01:35 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi,
Although I have not bought one myself, I think they are around $400 for the basic one (I think they call it 1.5 instead of 1.0 not sure why)
And for you guys with a kit, does the car retain it's normal smooth shifting if you only give it light throttle (1/2 or less?) or are the shifts always hard even at low load?
Thanks
Peter Horniak
Tokyo-Shi
Reg: 07-2006
Tuesday, March 22, 2011 - 01:50 pm, by:  Peter Horniak (Poida) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Boris, I quickly rang and ordered one this morning.
The Shift kits are $385 including postage (I believe, just waiting on invoice) and the the 1.5 is a smidge more hardcore than the 1.0 . Apparently the 1.0 is more suited to the twins and the 1.5 more to a single..?
That's what Mike reckons so I went with the 1.0.
I believe it will also retain a smooth shift at low throttle but a harder change and big throttle.
Peter
George Funa
Reg: 05-2006
Sunday, March 27, 2011 - 10:16 pm, by:  George Funa (Fun001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Boris
The shift kit is excellent mod. I have a stage 1 and it shifts nicely at low revs. Very good upgrade
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Monday, March 28, 2011 - 07:13 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks,
Does it shift like stock at low throttle? And at what throttle position does it begin to shift faster/harsher than normal?
I was after something that I could retain nice soarer like smooth shifts at low load.
Thanks. and Peter let us know how you go about installing the shift kit
George Funa
Reg: 05-2006
Friday, April 08, 2011 - 08:23 pm, by:  George Funa (Fun001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Boris
when driving normally you wont even think you have a shift kit. When you dive it full throttle you will experience quick solid gear changes.
A shift kit is definitely in the top 5 in performance upgrades for an auto soarer.
I am sure Peter will back me up
Dave Hall
Tasmania
4ltr V8 GT-L
Reg: 03-2011
Friday, April 08, 2011 - 10:39 pm, by:  Dave Hall (Dr0pb34r) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just for turbo's or is it a worthy performance upgrade for the V8's too?
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Friday, April 08, 2011 - 11:44 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is stage 1 still avaliable, as i take it this is the one for street to get normal shifts when not on full throttle.
Prashant Mohinda
Reg: 06-2010
Monday, April 18, 2011 - 07:36 pm, by:  Prashant Mohinda (Symptom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is mv autos the only place that do good shift kits for turbo soarers ?? I really want to get one but I want to make sure it is going to last and will be able to handle a t04z....
Ali Saeed
Monday, April 18, 2011 - 07:51 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
the auto wont be able to handle the t04z unless its been built.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Monday, April 18, 2011 - 10:03 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Handle a t04z is a pretty broad statement, how much power will the car be making? Any more than 250rwkw and you should be considering getting it rebuild with stronger parts and MV Automatics would be the place to talk to about this.
Prashant Mohinda
Reg: 06-2010
Tuesday, April 19, 2011 - 09:28 pm, by:  Prashant Mohinda (Symptom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much would we be talking to build the gearbox ??
Aaron Mead
Tuesday, April 19, 2011 - 10:01 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$2800 for a 400rwkw, $3500 for a spragless 500kw (T51+) proof box. Yes, its torque that matters, but MV can build a converter just on turbo and boost specs to suit, so they know what makes what.
Prashant Mohinda
Reg: 06-2010
Wednesday, April 20, 2011 - 09:42 pm, by:  Prashant Mohinda (Symptom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is the 500kw box just a better build in general or is there differences that change anything.
What I mean is if I had a gt35 or a t51 would the more expensive box be the best option for both or just the huge turbos ??
David Grima
1JZ-GTE TT
Reg: 07-2007
Saturday, May 14, 2011 - 11:33 am, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
does Mv Automatics have a website? ... done a search on google and nothing, just address and phone number listings.....
Sunday, May 15, 2011 - 06:59 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David they dont have a website . They build gearboxes . If you need more info , then call them .
ALot of workshops find too many people make too many enquiries over the internet , as its much easier to blow wind up someones arse when typing .
People who call on the other hand , are alot more serious about an enquiry . Not to mention the time it takes to sort through emails and answer them all .
Scott Casey
soarer v8
Reg: 02-2008
Sunday, May 15, 2011 - 08:10 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
why don't they hurry up and make a website and just have the "contact details" as their business phone number.
people are not wanting to go all over the place into stores and shop which takes them all day to look for a chair or tv. they want to shop online because its quicker and people are getting lazy with the internet available.
if business today don't take the advancing technology that is available "internet" they might/will lose customers.
would you go to an actual ebay store, wouldn't think so
Sunday, May 15, 2011 - 07:53 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Scott , these guys struggle to keep up with their workload as it is .
WHy would they want to take on any more if they cannot cope ?
Like i said , too many keyboard warriors and not enough time to filter the real from the fake for a very small business , when your on the tools for all the hours .
Scott Casey
soarer v8
Reg: 02-2008
Monday, May 16, 2011 - 06:54 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
true, i got what you are saying Daniel i am agreeing with you.
save them getting pulled off their work to answer calls etc during working hours.
at first use google sites as a advertising/information medium like i use for my local darts team and other teams to check out where they play.
just has a few pages on 2011 draw, averages, up coming events thats it. so they dont have to ring me while im working etc. imagine 90 calls per week just to ask where do we play next? thats why i made the site.
Boris Siljanoski
LS400 + Soarer.
Reg: 11-2007
Wednesday, May 18, 2011 - 09:09 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm pretty sure some of us ourselves work long hours so we don't get time to make phone calls during the day, which is why E-mail would be much more convenient.
Wednesday, May 18, 2011 - 09:31 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Northmead Auto are 1 of the top 2 if not the best along with AL's Race Glides ...
Northmead doesnt have a website at all ... They still build the toughest boxes in Oz .
Depends on the business like i said . Some shops are constantly snowed under with work ( as i know Northmead are ) and you literally have a waiting list .
Mitchell Haigh
Soarer JZZ31 N/A
Reg: 03-2011
Thursday, May 19, 2011 - 05:17 pm, by:  Mitchell Haigh (Lomenter) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
any good tranny places in brisbane or surrounding like ippy, gold coast, sunny coast or twmba?
Prashant Mohinda
Reg: 06-2010
Thursday, May 19, 2011 - 06:13 pm, by:  Prashant Mohinda (Symptom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
question directed at aaron or someone who knows is there any point getting the more expensive build if i am only chasing 400kw ish is it a better box in general or more siuted for bigger turbos. is it like cams in the sense of pros and cons ? what i mean is would the same turbo benefit more from the more expensive build ??
Matthew Crawford
JZA80 T88-38GK @630hp
Saturday, May 21, 2011 - 08:56 am, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have the strongest A340 box MV can build and it still isn't strong enough, I blew one of them up in 5 minutes.
They will *HOLD* 500kw but there is no aftermarket input shaft available for the A340 box- which ends up being the weak link
the only option for a car that gets launched making massive torque is a TH or a glide.
Prashant Mohinda
Reg: 06-2010
Sunday, May 22, 2011 - 12:17 pm, by:  Prashant Mohinda (Symptom) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
what a th ?
and i dont want a 2 speed glide matt.
is mv autos not able to make a gearbox that can HANDLE a t04z ??
Matthew Crawford
Monday, May 23, 2011 - 07:41 am, by:  Matthew Crawford (Doink) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
TH - Turbo Hydramatic,
Big GM box with massive aftermarket suport (inc input shafts)
Any gearbox can 'handle' any turbo, up to a point, it just depends how far away the point is :-)
Mike at MV will build a box to hold a certain amount of power without slippage, driveline shock is another issue. The A340 shaft just can't take high shock loads through its stock input shaft - simple matter of it not being engineered to handle the shock
Aaron Mead
Tuesday, May 24, 2011 - 04:11 pm, by:  Aaron Mead (Aaron) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Prash, my g'box is fine with my garrett T04z and 25 pounds. I think it would be still good with a HKS T04z and 30 pounds.
Ian Clifford
qld
hilux 1jz
Reg: 05-2010
Tuesday, May 24, 2011 - 06:15 pm, by:  Ian Clifford (Fezwa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have a box built buy western suburbs in brisbane works a treat its the same as mv box but not the spragless as mv said that was for drag only. if i break the box i will be going for a c4 from precision autos at beenleigh.
ian
