Wednesday, April 13, 2011 - 11:56 pm, by: Allan Langford(Allan)
just bolted a 7m-gte one up to my 1uz! you need to make sure the splines in the torque converter match the auto otherwise it seems they are all inter-changeable.
If you have a manual 7m-gte Transmission and you want to use it on the Soarer, this can be done. But you require a bellhousing for 1jz to R154, then you need all the bits such as the clutch master, slave, pedals etc, clutch from a Soarer jzz30
