Tuesday, July 05, 2011 - 12:01 pm, by: Rhys Salmon(1jzt04)
HI,
I have fried 2 & 3rd in my MX83, it has a 92 Celsior conversion (1uzfe & A341E)
I can get a worked A340E Supra box with Hi Stallie. (Assume 2jzgte)From a site member.
After changing bell housing to the A341E will this be ok, issue i might see are:
1) ECU (will manual shift, expecially if can use Hi Stall from A3640E, no need for auto shift)Can i just bypass somehow or just not plug the Ecu in and keep it manual shift. If so do i need to go ratchet, or current selector ok?
2) Input shaft, are they the same?
3) Stallie, are they the same size, or would i have to use 1u stallie
4)Length, will i need Driveshaft modification. (Assume these are the same )
5) I know some speedo sensors are in different locations, should these be the same?
Any info would be good if anyone knows if this is plausable.
