  Soarer Central * Transmission * Some w58 converted1uz questions :-) Previous Previous    Next Next
Daniel Marshall
V8 UZZ31 X2
Reg: 07-2011
Wednesday, October 17, 2012 - 07:00 am, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok cars been converted before I got it.
Would like to sort these.
Ect error _have been pointed in the right direction
Speedo_ think at 100 its doing 110 I'm getting a 2way can I just change ratios to fix?
Neutral switch_ its hooked up to clutch I've noticed if I push clutch in it drops revs to 7-800 with it engaged up around 1100.
Should I bridge these and ditch the clutch switch so it idles lower?
Thoughts and fixes please :-)
