  Soarer Central * Transmission * 3rd gear to 4th with Stage 1.5 MV Automatics shift kit is this right?? Previous Previous    Next Next
James Tims
Reg: 11-2008
Sunday, November 11, 2012 - 11:46 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi guys,
Just wanted to know my MV automatics 1.5 shift kit shifts fine between first and second, second to third but from 3rd to 4th when your doing mid range hundreds it revs right out to the 7000rpm before shifting, this seems a little delayed to me or is this normal???
Maybe it's also because I'm running less power at the moment at 13 psi as opposed to 18 psi because I'm using the stock ecu that I'm noticing this but if it should change earlier I'd like to know.
Cheers :-)
James Tims
Reg: 11-2008
Sunday, November 11, 2012 - 11:54 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just doesn't seem to chirp as quick form 3rd to 4th like it would from 1st, 2nd, to 3rd
Blake Gloyn
manawatu
soarer JZZ30 TT
Monday, November 12, 2012 - 04:01 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
as 4th gear is never changed into under power, they don't improve the 3rd to 4th shift. It's the cruise gear, and is likely to be weaker. 3rd gear at wide open throttle takes you to around 200-205km/h, so covers most eventualities on the drag strip.
James Tims
Reg: 11-2008
Monday, November 12, 2012 - 09:00 am, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm going to experiment with this again today to verify everything, do you have any idea what speeds and at which times the gears should be changing?
Blake Gloyn
manawatu
soarer JZZ30 TT
Monday, November 12, 2012 - 04:52 pm, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
with your foot flat, the gears should hold until around 6500-7000rpm and then change up. But with partial throttle, the rpm of the shift points are variable, as they are determined by input from the map sensor/speed sensor/throttle position sensor. The stage 1.5 shift kit should NOT try to change the factory programmed shift points, but just makes each shift faster/quicker(more crisp)
The 1.5 was designed to do really firm changes under full throttle, but more gentle changes(still crisper than the slurring factory gear change) under light throttle applications. It replaced the stage two, which did shudderingly firm gear changes at light throttle(or even just moving the gear lever from "park" to "R")
(note: it has been several years since i drove a stock ECU soarer.)
James Tims
Reg: 11-2008
Monday, November 12, 2012 - 06:53 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks heaps for your help Blake...I have noticed 2 things. A. I am a complete idiot as it was 2nd to 3rd gear on full throttle, the 2nd would rev right out to 7000 rpm on the dot then change which I hope is normal, sounds like it.
B. Because I have less power than before due to waiting on my emanage to be tuned I'm not used to it taking so long to reach the 7000rpm mark. So as long as on full throttle from 2nd to 3rd it revs right up to 7000 rpm we are sweet I'm a happy lad :-)
Friday, November 30, 2012 - 09:17 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't rev it to 7k it won't make power that high ;) 6500 is heaps
Ali Saeed
'97 JZZ30, '12 ZN6
Sunday, December 02, 2012 - 05:57 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen makes power all the way to 8k
James Tims
Reg: 11-2008
Sunday, December 02, 2012 - 06:06 pm, by:  James Tims (Timzy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Austen who mate? & is he running stockies or big single?
Sunday, December 02, 2012 - 07:33 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No way does Austens car make power to 8000 ... It might rev there but I guarantee power won't be past 7k ...
Ali Saeed
'97 JZZ30, '12 ZN6
Monday, December 03, 2012 - 04:25 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Daniel peak power is around 7000ish RPM (385rwhp). at 8000rpm his car makes 340rwhp.
James he has a gt3063 or 76.
