Monday, March 25, 2013 - 04:22 am, by: Garth Williams(Markiejam)
I recently converted my JZZ30 Soarer to manual and is now running the R154 transition, I am now noticing a vibration in the clutch pedal especially on boost at high rpm, while having the vibration the clutch pedal gets low and shifting becomes almost impossible until the rpm goes back down then it all goes back to normal, there is also a slight noise coming from the clutch that goes away if I depress or even put my foot on the pedal, this I suspect is the clutch bearing, I am having a problem finding the clutch kit since that's not a common care here in Jamaica and it is a conversion its a daily driver so i don't want the down time so I am trying to avoid taking it apart and search for a match up, can you help me find out what other car uses the same clutch kit, and help me diagnose my clutch problem Thanks
