  Soarer Central * Transmission * How much oil does the 154 take? Previous Previous    Next Next
Zac Clare
Reg: 05-2013
Thursday, August 29, 2013 - 08:57 am, by:  Zac Clare (Zactt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How much oil does my gearbox take and can anyone recommend a good brand?
Tom Richards
Thursday, August 29, 2013 - 09:24 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
google
"r154 gearbox oil"
plenty of info
Matt Newman
soarer tt
Reg: 11-2007
Thursday, August 29, 2013 - 12:30 pm, by:  Matt Newman (Soarersrock) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
pick your brand mate im a penrite bloke but its up to you i was recommended to use mineral 75w 90 gear oil but i think i might try a synthetic oil next to see if the shift is a little nicer but it takes about 2l from memory but the way to tell when its full is to have the car level and fill it till the oil trickles out of the fill point
cheers matt
Zac Clare
Reg: 05-2013
Thursday, August 29, 2013 - 02:27 pm, by:  Zac Clare (Zactt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Matt there's way too much info on google
Tai Johnsen
JZZ30 Pov Manual LSD & black!
Sunday, September 08, 2013 - 09:32 am, by:  Tai Johnsen (Privatejohnsen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I researched this a little while back and came to the conclusion that Castrol VMX 80 is what you want and change it every year or two ;)
Gary Rollason
TT 5 speed
Reg: 05-2007
Thursday, September 12, 2013 - 06:29 am, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I used Redline lightweight shockproof and it helped somewhat with the shift.
Don't overfill it! If it overflows through the filler hole, you've got too much oil!
http://soarercentral.com/sc-forum/messages/31678/259481.html?1242111006
