  Soarer Central * Transmission * Jolt when putting into "D" Previous Previous    Next Next
Joseph Kelly
N.S.W
Reg: 09-2012
Tuesday, May 06, 2014 - 05:37 pm, by:  Joseph Kelly (Phenonix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Start the car, put it into "D" large clunk and car jumps forward, i don't think any jolt happens when put into "R"
What could be wrong?
Thanks
Matchy Loi
GTT
Tuesday, May 06, 2014 - 06:38 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you played with the line pressure or did any work to that area of the engine bay lately?
Joseph Kelly
N.S.W
Reg: 09-2012
Tuesday, May 06, 2014 - 06:55 pm, by:  Joseph Kelly (Phenonix) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No, i have done nothing at all.
Dave Rose
wa
UZZ31 / ML320 CDI
Tuesday, May 06, 2014 - 10:32 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Check auto fluid level and colour
Rob Charles
Reg: 07-2014
Tuesday, October 07, 2014 - 05:13 pm, by:  Rob Charles (Pearl_white) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jolt when putting car in D.
Your car when warm should idle around 600rpm.
If it is idling at 900rpm-1000rpm, you will get a jolt when putting car in drive.
Same thing happened to me for weeks til I adjusted TPS.
Good luck!
(But check fluids first.)
