Drew Charlwood
Tinkerer NSW V8
Posts: 86 Reg: 08-2010
| Hey guys. Just picked up a tremac T56 gearbox. It came from a VY SS ute. Came with the tail shaft and exide clutch. What else do I need. I know I need the adapter plate. And pedal. What else will I need. Thanks. |
Nik Peacock
TryHard Tasmania Blown V8 6 Speed Manual
Posts: 234 Reg: 05-2006
| Tailshaft and clutch are no good to you, need a custom flywheel and clutch, tailshaft from a tt and that will need to shortened, pedals master cylinder short shifter. Best get in contact with Neil Griffiths and see if he still does the kits |
Scott Vim
Goo Roo Vic Soarer (1uz) Chaser (1jz)
Posts: 1146 Reg: 12-2010
| I'm guessing it can either be a manual or auto tailshaft since it needs to be modified anyway. Might as well use an auto one since people give them away these days. |
Shane Haverkamp
Goo Roo nsw soarer TT
Posts: 1069 Reg: 10-2007
| you'll need: a master cylinder clutch lines manual shifter surround (plastic interior) not sure what you do with the speed sender/sensor |
Andrew Brown
TryHard NSW V8 6 Speed Manual
Posts: 252 Reg: 10-2012
| you'll need a speedo corrector for sure, t56 pulse rate is way higher than toyota ones. mine still reads 10% over on best adjusted setting lol |
Nik Peacock
Posts: 235 Reg: 05-2006
| Lookup speedohealer, I have one in mine and have the speedo 100%, can even make tiny adjustments for new tyres |
Andrew Brown
Posts: 254 Reg: 10-2012
| can you link me to that Nik? all the ones I find are for bikes lol |
Nik Peacock
Posts: 236 Reg: 05-2006
| That's the one Andrew, email them and tell them that you need a unit for 2 wire sensor to a 3 wire vehicle, if I remember correctly you need to measure the resistance or if it's an open or closed circuit of the sensor on the t56 (they well tell you what to do) and send that as well |
Andrew Brown
Posts: 255 Reg: 10-2012
| Hey Nik, I got a response from the speedo healer guys. does this sound about right? - SH-V4 Spec Kit (2w to 3w) This is a complete kit with wiring harness |
Nik Peacock
Posts: 237 Reg: 05-2006
| I think so Andrew, I'll have a look on the week end when I'm next at the garage where I keep it and let you know |
Nik Peacock
Posts: 238 Reg: 05-2006
| Yep V4 |
Andrew Brown
Posts: 256 Reg: 10-2012
| ok so final question.. this corrects the digital dash speedo right? you dont read from the unit itself? |
Nik Peacock
Posts: 239 Reg: 05-2006
| Yep, I did have to put a resistor across 2 wires somewhere as the t56 sensor seems to pickup a lot of interference and makes the speedo jump up intermittently while standing still, not good if your on the outside as it triggers the auto door lock |
Drew Charlwood
Tinkerer Qld V8
Posts: 87 Reg: 08-2010
| How much did it cost you guys to complete your conversion? |
Andrew Brown
Posts: 257 Reg: 10-2012
| Thanks Nik all ordered now My total cost was $4k in n out but i was the test dummy as it hadn't been done before hehe |
Nik Peacock
Posts: 240 Reg: 05-2006
| I'd say about 7K done myself with full kit from Neil with twin plate and brand new T56 magnum, one piece 3.5" tailshaft. Jesus Andrew 4K is below cost, good deal. |
Drew Charlwood
Tinkerer Qld V8
Posts: 88 Reg: 08-2010
| Holy. I'm planning on doing it all myself but if I have trouble I might be able to get Mario Lantini to give me a hand. He replaced my engine a while back up north. Do you guys know where I can pick up most parts? For this build. |
Andrew Brown
Posts: 258 Reg: 10-2012
| Neil may still make kits, that would be the easiest way by far. I got mine done by Brintech Customs down here in Sydney, they could get you/make you everything you need as well but you're in qld so not real convenient for you |
Drew Charlwood
Tinkerer Qld V8
Posts: 89 Reg: 08-2010
| Does anyone have Neil's contact details |
Andrew Brown
Posts: 261 Reg: 10-2012
| He's like the illusive man lol best to find him on Facebook, he's quite talkative on there look for Neil John Griffiths |
Ben Lipman
Goo Roo SA Soarer TT manual, plus TT track car, plus a spare shell
Posts: 3839 Reg: 04-2006
| Yeah, Neil was talking to me about running a T56 magnum in the race car a couple of weeks ago. I'll cross that bridge if I ever break the R154 |
Clayton Carlyle
TryHard NSW v8 soarer twin turbo
Posts: 343 Reg: 04-2009
| You can buy the adaptor plus flywheel & clutch of EBay, castlemane rod shop do a whole package for $1500.00 The adaptor will work with UZ & JZ engines. If you want cheaper still just buy the adaptor & get a twin or triple plate nascar clutch for nothing on US eBay. Pedals & master from a wrecker. You can shorten the V8 driveshaft but you'll need to purchase a uni of the D/shaft shop. Sideshow can sell you a speedo corrector ready to go. |
Clayton Carlyle
Posts: 344 Reg: 04-2009
| I'm currently putting a Tr6060 into my supra for under $3000.00 Much cheaper than an ancient v160 |
Drew Charlwood
Tinkerer Qld V8
Posts: 90 Reg: 08-2010
| Thanks for the info and direction clayton |
Stuart Gale
Newbie New South Wales SC400
Posts: 5 Reg: 01-2015
| I have sourced a T56, from a BA XR8, to fit to my UZZ31. What needs to be done with the ECU? Everything else I can sort out or fabricate. |
Andrew Brown
Posts: 295 Reg: 10-2012
| Ford t56 is garbage, go get the Holden version and try again nothing needs to be done to the ECU |
