  Soarer Central * Transmission * 5 speed auto for 1UZ? Previous Previous    Next Next
John Stafford
Qld.
Soarer UZZ31 GT-L V8 and a Ford Territory Ghia AWD
Reg: 02-2010
Sunday, February 22, 2015 - 06:59 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was on ebay U.S. and noticed a number of 5 speed auto boxes for the U.S. 1UZ VVTi. Do they fit our engines?
Ali Saeed
RSP JZZ30
Monday, February 23, 2015 - 04:50 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I believe they will..wiring would be interesting im sure
John Stafford
Qld.
Reg: 02-2010
Monday, February 23, 2015 - 07:38 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
who could do the wiring and how much would such a venture cost Ali?
UZZ32 No.32 & JZZ31 3.0GT
Monday, February 23, 2015 - 09:13 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
They wont work with the standard computer from 4 speed 1UZ engine. The A650e 5 speed is very different electronically, an A340e computer could never control it.
The only way you could get such a result is a complete engine swap with a VVTi 4.0 1UZ or 3UZ with the factory 5 speed fitted.
Cost wise what its worth it wouldnt be that effective as an upgrade, unless your existing engine has problems.
That said, whether or not a vvti engine/5 speed computer could be wired in to the older 1uz loom just to run the 5 speed could be a possibility but I would say all sorts of errors would occur if its not running the rest of the engine in tandem.
Still, Such a gearbox would make a massive difference to a Soarers off the line performance.
Pretty good ratios - 1st 3.3 vs 2.8 - 2nd 2.18 vs 1.53, 3rd 1.42 vs 1.00
Mechanically they bolt in fine, but the rear output flange on the early 4 speed box is smaller than the 5 speed so the driveshaft would need to be modified or a SC400 vvti spec shaft imported to have the correct larger size.
John Stafford
Qld.
Reg: 02-2010
Monday, February 23, 2015 - 09:19 am, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Those gear rations sound great but as you say, the cost would not warrant the change and my engine is fine. Thanks Mike
Daniel Bonnor
soarer uuz31
Reg: 06-2014
Monday, February 23, 2015 - 11:52 am, by:  Daniel Bonnor (Majorlunacy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i was thinking of doing this swap years ago found a aftermarket controller that would run it the thing that stopped me was cost and finding spares in aust
John Stafford
Qld.
Reg: 02-2010
Monday, February 23, 2015 - 03:20 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yes, the cost seems over the top, so scrap that idea.
Daniel Bonnor
soarer uuz31
Reg: 06-2014
Monday, February 23, 2015 - 03:38 pm, by:  Daniel Bonnor (Majorlunacy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
if you want the extra gear and keep the auto maybe look at a overdrive unit like the one's from gear vendors
John Stafford
Qld.
Reg: 02-2010
Monday, February 23, 2015 - 04:12 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Daniel,
I have sent to them but they also look pretty expensive and then it looks like I would need a new tailshaft?
Thanks for the lead anyway.
John Street
VE Calais V8, 2009 Saab 9-3 Turbo
Monday, February 23, 2015 - 05:26 pm, by:  John Street (Rex2ce) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
John, Aussie delivered Lexus LS 400 have a 5 speed box
http://www.carsales.com.au/private/details/Lexus-LS400-1998/SSE-AD-3134256/
John Stafford
Qld.
Reg: 02-2010
Monday, February 23, 2015 - 10:53 pm, by:  John Stafford (Johng12) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok, so someone with a clapped out V8 Soarer could do a project rebuild if they got hold of one of these :-)
Tuesday, February 24, 2015 - 05:39 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oddly enough John, I thought about this idea part way through last year. I was going to look into using a 3UZ-FE with the 5 speed auto or a W58 as a nice platform to build a good Soarer but then along came a UZZ32 so I just had to scrap the 3UZ plan.
That said I think it's a very good upgrade for drop in performance to something like a late model 3L faclift Soarer, 2JZ, 3UZ in, with minimal mechanical custom work. Just a bit of wiring and general certification work. A custom exhaust would be the hardest part. But 300hp+ and the best part of 450nm of V8 VVTi grunt it would sure be impressive.
Speaking of the A650e, I did successfully run one behind an early 1UZ in my BMW E36 conversion. It sure was good but did take a lot of custom programming with a PCS TCM-2000 controller and no matter how many months of constant changes I made to get it working as perfect as I could it still wasn't as smooth as the stock ECUs ability to control it, fine at 50-100% throttle but it wasnt as easy going under 50% particularly on the 1-2nd up shift and 3rd to 2nd downshift. It still worked well though! Here is how it went in manual shift mode down the strip...
