Friday, March 20, 2015 - 01:58 am, by: Matt Brown(Jzx83t)
Hi Guys, I have a 1JZ single turbo fitted with a A341e gearbox.
That gearbox has decided to die and I think I'm going to have to replace the box with a A340. Does anyone know if its a straight swap. Im assuming the bellhousing may need to be interchanged between the boxes
Friday, March 20, 2015 - 04:02 am, by: Blake Gloyn(Blakenz)
assuming you have a A341 from a jza70 supra or a jzx90 chaser maybe, the box should bolt right up. I don't know why, but the A340 is a stronger box than the A341. See if you can afford to put an MV Automatics upgraded valve body in it, makes them last heaps longer again.
