  Soarer Central * Transmission * Drive shaft coupling Previous Previous    Next Next
Jan van Berendonk
Reg: 08-2012
Saturday, April 11, 2015 - 12:53 pm, by:  Jan van Berendonk (Janjen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone know the bolt spacing on the drive shaft coupling, or have a spare they can check the measurement on? Looking to do a T56 change over and I am wondering how close dimensionally the Toyota and VZ Yoke rubber coupling are.
Daniel Marshall
V8 UZZ31 X6 jzz30x1
Reg: 07-2011
Saturday, May 16, 2015 - 06:56 pm, by:  Daniel Marshall (Ydass) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
vz
pcd-96mm
bolt size-12mm
overall size-133mm
id/spigot sarea-49mm
thickness-35mm
soarer
pcd-120mm
boltsize-14mm
overall-160mm
id/spigot area-64mm
thickness-43.5mm
pcd boltsize
