Andrew Brown
Tinkerer NSW SC400 GT-L V8
Posts: 68 Reg: 10-2012
| Hey guys, Just wondering whether I can use any type of t56 gearbox for a conversion or whether I have to use a specific type eg. Holden, ford etc. Cheers! |
Nik Peacock
TryHard Tasmania V8 6 Speed Manual
Posts: 204 Reg: 05-2006
| needs to be a holden one, cant remember the exact year/model, you can also use the magnum just have to machine a couple of grooves into the adapter plate, second hand box $1500-$2000, brand new magnum from dellow etc about $3200, removes any risk of getting a dud second hand one |
Andrew Brown
Posts: 69 Reg: 10-2012
| Thanks for the clarification Nik, just picked up a holden t56 for $1200 only 80,000km on it |
Andrew Pickard
Tinkerer ACT TT
Posts: 17 Reg: 03-2013
| HI Andrew, I'm in the exact same process but can't find an adapter plate, the only thing currently available is the dellow bell-housing for $660. What are u planning to use and any idea where to get the adapter plates from? Cheers Andy |
Andrew Brown
TryHard NSW SC400 GT-L V8
Posts: 123 Reg: 10-2012
| Nah screw dellows lol they want too much money, i'm getting my adapter plate made up from Brintech custom cars. Laurence is who you'll want to speak to, his number is 0412 723 052. he'll be able to help you out |
Andrew Pickard
Tinkerer ACT TT
Posts: 19 Reg: 03-2013
| Thanks for teh info Andrew, did you give them the CAD file? I will ring them today. Cheers Andy |
Andrew Brown
Posts: 126 Reg: 10-2012
| Nah Laurence mentioned he had the CAD file and said he can get them made up as he's doing my whole conversion, but I've just realised that you have a 1jz and the plates being made are for 1uz |
Scott Vim
DieHard Vic Soarer (1uz) Chaser (1jz)
Posts: 623 Reg: 12-2010
| How much does the whole thing cost in parts and how much in labour? |
Andrew Brown
TryHard NSW Unbadged Modified V8
Posts: 128 Reg: 10-2012
| i sourced my own t56 box for $1200, got manual soarer pedals and master cylinder off here from Lew Radbourn for $200. Brintech supplying t56 adapter plate for $450, manual flywheel $390, clutch kit $650, spigot bearing $25 then around $2000-2500 labour so worst case total is... $5415 only lose the car for a weekend I highly recommend Brintech for the job, they have done this conversion many times, not always in a soarer though haha! |
Scott Vim
Posts: 624 Reg: 12-2010
| In Sydney? I've got a r154 but I'm wondering if the t56 is better and/or cheaper if I sell my r154. |
Andrew Brown
TryHard NSW V8 Beast
Posts: 131 Reg: 10-2012
| Yeah in sydney, unit 42 / 20 Tucks Rd Seven Hills to be exact Well neil griffiths recommends the t56 and it is built like a brick sh.ithouse to deal with holden ss power, let an auto 1j have the r154 and convert to 6 speed t56 ;) |
Scott Vim
Posts: 625 Reg: 12-2010
| Does an r154 collect as much these days? |
Scott Vim
Posts: 626 Reg: 12-2010
| The 6th gear over drive is appealing... |
Andrew Brown
Posts: 132 Reg: 10-2012
| Well r154 are rarer to come by and t56's are easy to find so I reckon you'd get a fair amount for your r154 Yeah thats what won me over in the end |
Allan Langford
DieHard Vic UZZ31
Posts: 921 Reg: 05-2010
| Scott unless you are blowing it up the R154 shifts better then a T(ruck)56 |
Andrew Brown
Posts: 134 Reg: 10-2012
| Neil said the r154 shifts like a commercial vehicle lol t56 is from ss commodore and maloo utes |
Allan Langford
DieHard Vic UZZ31
Posts: 922 Reg: 05-2010
| GM products are known for refinement the R154 is no work of art but compared to a T56 if strength is a not an issue I know what I would have! |
Andrew Brown
Posts: 135 Reg: 10-2012
| Mm maybe but then theres the issue of having 6th gear or not |
Scott Vim
Posts: 627 Reg: 12-2010
| R154 have no issue with 250rwkw do they? |
Joshua Rao
Goo Roo WA TT (for sale $5.2k), 97 Blk UZZ31, 97 JZZ30 vvti turbo white manual, 96 vvti turbo manual, Legnum VR4, MR2 sw20, Alfa 156
Posts: 3255 Reg: 09-2006
| No there strong as |
Andrew Brown
Posts: 136 Reg: 10-2012
| It pretty much comes down to wanting a sixth gear, or going crazy with torque and power as to which one you choose If you've already got the r154 id say stick with it as you could wait for a while to find a decent cheap t56 |
Brett Harrison
DieHard QLD JZZ30
Posts: 845 Reg: 09-2005
| The newer TR6060 is a much nicer box if you can afford it. |
Ali Saeed
Goo Roo WA RSP JZZ30
Posts: 4417 Reg: 09-2007
| How much are TR6060s? I think now you can almost afford to go with v161. Theres a swap in Supra forums for $4k. Obviously you will need the big diff as well so add in another k. |
Andrew Brown
Posts: 139 Reg: 10-2012
| Saw one on ebay for $3100 so I'm assuming they're all around that mark |
Ian Johnston
Goo Roo South Australia 1995 UZZ31, BA XR6Turbo Ute. 2007 VE GTS.
Posts: 1916 Reg: 07-2005
| I see Castlemaine Rod shop do an adaptor plate for the T56 to V8 auto bell housing, and the six cyl as well. |
