Saturday, October 19, 2019 - 03:11 pm, by: Marcus Cimino(Spike28278)
My soarer is vibrating heavily in drive. Its a 1991 v8.
So here's what I found. I jacked up the rear (tems off) started it and put it in drive. Under acceleration it seems to struggle a little and shudder. This only happens in Drive. Not reverse or 2 or L.
Only noticed this as I had to replace my speed sensor as the speedo is erratic. Also I've tested this with another ecu from a working soarer still same issue. Wanna know if there is anything else to check?
