  Soarer Central * Transmission * Shift Kit Previous Previous    Next Next
Sunday, March 19, 2006 - 02:27 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey, Im looking for someone in Sydney who can supply and fit a Shift kit for a 1991 TT soarer? And roughly what price im looking at as im working out a plan of attack on it,hehe:-) thanks.
Chris Davey
Corona
Monday, March 20, 2006 - 11:00 am, by:  Chris Davey (Chris_davey) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have a look down the page as I am sure there is another thread re this. Find UKautomod and follow that :-) Do it yourself and it will cost you about $10 maximum :-)
Friday, March 24, 2006 - 10:12 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone in Sydney Sell MV's shift kits for a 91 TT soarer? If so how much? and how much to get it installed?
Yes basically i dont wanna do it myself, new to these cars and llack of time also. Much rather get it done in a shop at the right price:-) cheers
Anish Varsani
V8 UZZ30
Saturday, March 25, 2006 - 11:02 am, by:  Anish Varsani (Yomama) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you order the shift kit, you can get any transmission shop to install it. Don't take it to a normal mechanic as he may not have gasket material on hand to cut you a new gasket.
$150 should get it installed, sump resealed and transmission flushed.
Simon Triantafillou
Soarer Turbo
Saturday, March 25, 2006 - 11:11 am, by:  Simon Triantafillou (Soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is a tutorial on Planet Soarer on how to install it yourself if you can jack the car up at home. You don't need any special knowledge to do it.
Soarers don't use gaskets for the transmission pan. Just silicone/gasket sealant.
Saturday, March 25, 2006 - 12:41 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I dont mind taking it to a shop that can do it. Just dont like Mechanics using my car as their 1st if ya know what i mean. Something always gets F*&Ked up then,hehe. Ok, thanks guys, will give MV a call on monday.
Also Any of you out there with a 1.0 Shift kit can tell me how much better than stock it was? Dont wanna quite go the 1.5 if its tooo harsh(gotta keep the mrs happy) after all, she let me buy it:-)
UZZ-32 V8 Soarer #138
Saturday, March 25, 2006 - 01:46 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I went for a ride in Benny's car with a stage 1, It seemed pretty good. Quite smooth with normal driving, but fairly firm when flogging it.
Saturday, March 25, 2006 - 04:17 pm, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't do the 1.5. She will be very unhappy. You'll probably get away with a stage 1 if you drive sensible while she's in the car.
Jan Christiansson
Soarer V8
Saturday, March 25, 2006 - 04:49 pm, by:  Jan Christiansson (Janoc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And Niall in Botany can do it as well.
Steven Nanevski
JZZ30 Twin Turbo
Saturday, March 25, 2006 - 04:49 pm, by:  Steven Nanevski (Imprestik) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pretty sure Niall could do it here in Sydney, a Expert when it comes to soarers, just double check with him though.
Sorry don't have his number on me at the moment, business is called Bond Auto Tech, located in Botany.
Saturday, March 25, 2006 - 11:18 pm, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ok cheers guys :-)
