  Soarer Central * Transmission * First Prob with new car Previous Previous    Next Next
Nilhan Jayaweera
3L striaght six
Monday, March 27, 2006 - 09:09 pm, by:  Nilhan Jayaweera (Logic) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey all. Just brought a 3L soarer and im loving it but have found my first problem. It;s in the transmission. I have an auto and i find that the first time i drive my car usually for the day i have no problems. However, if i decide to stop my car, turn off the engine etc then come back to my car im a short period of time my auto transmission does not respond for a couple of minutes. When you push the button ontop i can feel it not clicking in and thus i sit their for a couple of minutes fiddling with my auto stick until eventually it responds and im away. I bought the car knowing that i had dirty transmission fluid and am going to replace it this week. Would that be the main problem as to why it's taking a couple more minutes to respond or could it be more of a mechanical problem. I noticed as well if the car has been in the sun for a long period of time it also occurs. Any help would be appreciated
Nilhan Jayaweera
3L striaght six
Monday, March 27, 2006 - 09:11 pm, by:  Nilhan Jayaweera (Logic) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"NOTE" i did do an NRMA inspection before i bought the car and it came up with no issues other than the transmission fluid being dirty
3.0 GT
Tuesday, March 28, 2006 - 07:13 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And make sure that whoever does it does a proper flush, not just a sump drain.
Ugh, that picture of the guy with the chick painted on his back is just disturbing.
Nilhan Jayaweera
3L striaght six
Tuesday, March 28, 2006 - 04:36 pm, by:  Nilhan Jayaweera (Logic) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What should i be asking for when asking for a "proper flush"". I just called them and they said they would to the transmission flush for $60. Is that 2 cheap?
Sam Schreck
vvt-i JZZ31
Tuesday, March 28, 2006 - 07:02 pm, by:  Sam Schreck (Schreck300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
make sure they do this
http://soarercentral.com/sc-forum/messages/37/1366.html?1104261037
